Replace big block water pump idler pulley - how? #1487106
08/19/13 10:35 PM
08/19/13 10:35 PM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
I want to replace the water pump idler pulley on my big block because the bearings feel worn out. I bought a replacement from O'Reilly Auto Parts. When I looked up the part originally it was a Murray 45900 as shown on this link:
http://www.oreillyauto.com/site/c/detail...7&ppt=C0331
But when I called to find out if they had it in stock, they told me it cross-referenced to a Gates 38038. So I bought it, and it looks like it might fit. But the old pulley has a threaded stud in it that I don't know how to remove, or even if it's removable. I tried tapping it out with a hammer but it didn't budge. Has anyone tried to replace one of these? Is it even removable? If it is, how do you get it out? See the attached pictures.
69 Chrysler 300 Convertible 77 Chrysler New Yorker Brougham 2-dr 03 Jeep Grand Cherokee Limited
Re: Replace big block water pump idler pulley - how? [Re: mantonas] #1487107
08/19/13 10:37 PM
08/19/13 10:37 PM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
Here are some pictures
Re: Replace big block water pump idler pulley - how? [Re: mantonas] #1487108
08/19/13 10:39 PM
08/19/13 10:39 PM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
Front of old and new pulleys
Re: Replace big block water pump idler pulley - how? [Re: mantonas] #1487109
08/19/13 10:40 PM
08/19/13 10:40 PM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
Back of old and new pulleys
Re: Replace big block water pump idler pulley - how? [Re: mantonas] #1487110
08/20/13 02:39 AM
08/20/13 02:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you look closely at the old pulley you will see the tack welds holding the 2 cover plates on that protect the bearing ... notice I said WELDED , you are not going to get the threaded stud out by trying to tap it out without destroying something.
Re: Replace big block water pump idler pulley - how? [Re: JohnRR] #1487111
08/20/13 06:57 AM
08/20/13 06:57 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
JohnRR is right. The cover is welded in multiple places around the front of the pulley (that cover is visible when installed on the engine). I cut mine off thinking I could just replace the bearing. However after getting the cover off and the stud out (which you will also have to do), I discovered that the cover also serves to hold the bearing in the pulley. It is not a press fit and you would have to weld a cover back on to be able to use the original pulley.
jess
Yeah, it's hopped up to over 160...
Re: Replace big block water pump idler pulley - how? [Re: jt4406] #1487112
08/20/13 07:33 AM
08/20/13 07:33 AM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
Thanks for the info, I did not notice the weld.
It seems like the real irreplaceable part is the stud with the flat side to line up with the "D" shaped hole in the bracket. If you cut off the original pulley front cover and remove the stud, will it fit into the replacement pulley? Is it a shoulder bolt that press fits into the pulley and if so is it the right diameter?
Re: Replace big block water pump idler pulley - how? [Re: mantonas] #1487113
08/20/13 09:35 AM
08/20/13 09:35 AM
Wausau,Wisconsin
Kilrbee Offline
Kilrbee  Offline
Wausau,Wisconsin
Mega Parts carries a very nice reproduction of these pulleys!!
Re: Replace big block water pump idler pulley - how? [Re: Kilrbee] #1487114
08/20/13 01:53 PM
08/20/13 01:53 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Yes, fits perfect, that is what I did. I also found a small suitable washer to serve as a guard for the bearing seal.
Jess
Re: Replace big block water pump idler pulley - how? [Re: jt4406] #1487115
08/20/13 01:56 PM
08/20/13 01:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most JY cars have idlers that have a large washer that was between the bolt and pulley.Then you just need the correct thread bolt.Rocky
Chrysler Firepower
Re: Replace big block water pump idler pulley - how? [Re: therocks] #1487116
08/21/13 08:37 PM
08/21/13 08:37 PM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
I know what a YJ car is (Jeep Wrangler), but what is a JY car?
Re: Replace big block water pump idler pulley - how? [Re: Kilrbee] #1487117
08/21/13 08:46 PM
08/21/13 08:46 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Link??
1MYTGTX
Re: Replace big block water pump idler pulley - how? [Re: mantonas] #1487118
08/21/13 08:55 PM
08/21/13 08:55 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
JY=Junk Yard.
Re: Replace big block water pump idler pulley - how? [Re: bobby66] #1487119
08/21/13 09:20 PM
08/21/13 09:20 PM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
I guess all cars are eventually JY cars.
Re: Replace big block water pump idler pulley - how? [Re: 1MYTGTX] #1487120
08/22/13 01:36 AM
08/22/13 01:36 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Link??
Mega Parts Pulley
