518 behind a 500" stroker; Lock up or not? #1487025
08/19/13 09:11 PM
08/19/13 09:11 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I am going to freshen up the 500" Wedge in the Cuda this winter and plan on putting a 518 behind it when I put it back in.
Would you use a lock-up converter or not? And why. I understand that there are some restrictions on which lock-up converter can be used with the conversion bell housing.
The Cuda has 3.91s and a streetable 4,000 stall PTC in it now. If it is worth it, I don't mind buying another converter. 55 MPH is about 2,800 RPM now and there is no problem driving a couple of hours like that. The tranny does not get hot.
But I was wondering if the lower RPM that the overdrive would have it at at that speed would cause too much heat without a lock-up converter.
Anyone with experience with this have an opinion?
Master, again and still
Re: 518 behind a 500" stroker; Lock up or not? [Re: DaveRS23] #1487026
08/19/13 10:20 PM
08/19/13 10:20 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I believe you can only use a lock up converter on a lock up trans.
Re: 518 behind a 500" stroker; Lock up or not? [Re: stumpy] #1487027
08/20/13 10:36 AM
08/20/13 10:36 AM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Yes, two different trans. I was wondering which core to pick up.
Re: 518 behind a 500" stroker; Lock up or not? [Re: DaveRS23] #1487028
08/20/13 10:48 AM
08/20/13 10:48 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
for that much power i'd get a non lockup.
Re: 518 behind a 500" stroker; Lock up or not? [Re: DJVCuda] #1487029
08/20/13 01:47 PM
08/20/13 01:47 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Or be very carful not to put to much power to it when it's locked up. Can you set up a 518 to control OD and lockup seperatly?
Re: 518 behind a 500" stroker; Lock up or not? [Re: WO23Coronet] #1487030
08/20/13 01:54 PM
08/20/13 01:54 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I believe that your selection will also be determined by converter availability. Meaning...Im not sure that you can get a 4k flash lock up vert for the 518?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 518 behind a 500" stroker; Lock up or not? [Re: Von] #1487031
08/20/13 02:07 PM
08/20/13 02:07 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
You may want to talk with some of the people that work with the diesel 618s about the availability of high torque clutches for lockup converters. Your stroker is getting close to diesel torque, but pulls more rpm. The lockup should only be used for part throttle cruise, so some throttle/ vacuum/trans pressure switch(es) should be setup to control that.
Re: 518 behind a 500" stroker; Lock up or not? [Re: Von] #1487032
08/20/13 02:07 PM
08/20/13 02:07 PM
dogdays Offline
dogdays  Offline
From the casual manner in which you mention putting a 518 in your 'Cuda over the winter, I am torn between two assumptions:
1. You are a master fabricater and won't have any problems slicing and dicing the torsion bar crossmember to get the transmission to fit.
or,
2. You have no idea of the challenges that lie before you.
So, which is it? One thing for sure, it's not a bolt-in swap!
Regarding the lock-up converter: There are two schools of thought, both valid. It is possible to use a regular converter, it is also possible to use a professionally built lockup converter. Either one will work, but if you go lockup you need to have someone build it who is familar with them.
There are lockup converters behind Diesels that make nearly twice the torque that your engine will. The torque converter clutch just has to be built for the job.
R.
Re: 518 behind a 500" stroker; Lock up or not? [Re: dogdays] #1487033
08/20/13 04:14 PM
08/20/13 04:14 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Very true. But, again..I wonder if anybody makes a lockup 518 vert with real (3500-4k, plus) flash speed capabilities?
Re: 518 behind a 500" stroker; Lock up or not? [Re: DaveRS23] #1487034
08/20/13 07:06 PM
08/20/13 07:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The reality is that the majority of the time the converter would be locked up you won't have your foot in it, you'll just be cruisin' so the converter clutch doesn't have to be extra beefy. Even then, if it's properly setup, the converter will unlock with heavy throttle.
Re: 518 behind a 500" stroker; Lock up or not? [Re: John_Kunkel] #1487035
08/20/13 08:50 PM
08/20/13 08:50 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
My buddy has one behind a strong 440. He built it and controls OD and CC with toggles on the console. Shifts very nice and yes OD/CC is only on when highway cruising. Run's easy mid 12's in street trim...shifter in drive You will want someone to build you a converter that works with your combo. I don't recall who did his..but it flat out works!!
Re: 518 behind a 500" stroker; Lock up or not? [Re: John_Kunkel] #1487036
08/20/13 08:55 PM
08/20/13 08:55 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I guess I should have said that I certainly do not expect the LU or the OD to hold any where near full power. It will only be for cruising along at light throttle.
As for requiring a master fabricator, there are adapter tranny mount brackets out there and I can surely cut the bell off of the 518 in preparation for bolting on the adapter bell. There are several very good and informative threads that will be invaluable for this.
A 518 core is $150 at the pick a part yards when they pull it, and I plan to test fit it before I spend the coin to beef it up. So if the wheels do fall off this project, I am not in up to my ears in it.
I am just curious about 2 things mainly;
First, with 4,000 stall and 3.91s, will the cruise RPM be so low that there will be enough slip in the converter without LU to give me too much heat while cruising.
Second, what would you guys run and why? LU or non LU. And if the LU, what are the restrictions that I would run into?
PTC has been building my converters and do a super job. I will talk to them also, but just wanted some opinions here first.
And if need be, I can back off the stall speed. We do not run the KOS circuit much any more. But would like to ready if it picks back up.
Thanks for the input, guys! I really appreciate it.
Re: 518 behind a 500" stroker; Lock up or not? [Re: DaveRS23] #1487037
08/21/13 05:08 PM
08/21/13 05:08 PM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
I am going to be running a 618 in my challenger. I have already cut off the bell. I am not sure if I am going lockup. The diesel converter is a lot larger than the 727 and with an ultra bell obviously we are going to have to run a stock size 727 converter. I have not done much research but I am not sure if there will be enough space to put clutch material to hold high hp applications.
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: 518 behind a 500" stroker; Lock up or not? [Re: Jambbii] #1487038
08/21/13 06:37 PM
08/21/13 06:37 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Be sure to slip in a gas engine governor if you haven't already. 3200 rpm shift points aren't much fun.
- Stu Harmon
