518 behind a 500" stroker; Lock up or not?
#1487025
08/19/13 09:11 PM
08/19/13 09:11 PM
Posts: 12,098 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I am going to freshen up the 500" Wedge in the Cuda this winter and plan on putting a 518 behind it when I put it back in.
Would you use a lock-up converter or not? And why. I understand that there are some restrictions on which lock-up converter can be used with the conversion bell housing.
The Cuda has 3.91s and a streetable 4,000 stall PTC in it now. If it is worth it, I don't mind buying another converter. 55 MPH is about 2,800 RPM now and there is no problem driving a couple of hours like that. The tranny does not get hot.
But I was wondering if the lower RPM that the overdrive would have it at at that speed would cause too much heat without a lock-up converter.
Anyone with experience with this have an opinion?
Master, again and still
Re: 518 behind a 500" stroker; Lock up or not?
[Re: WO23Coronet]
#1487030
08/20/13 01:54 PM
08/20/13 01:54 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I believe that your selection will also be determined by converter availability. Meaning...Im not sure that you can get a 4k flash lock up vert for the 518?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: dogdays]
#1487033
08/20/13 04:14 PM
08/20/13 04:14 PM
Von
NE Oklahoma
There are lockup converters behind Diesels that make nearly twice the torque that your engine will. The torque converter clutch just has to be built for the job.
Very true. But, again..I wonder if anybody makes a lockup 518 vert with real (3500-4k, plus) flash speed capabilities?
[Re: DaveRS23]
#1487034
08/20/13 07:06 PM
08/20/13 07:06 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The reality is that the majority of the time the converter would be locked up you won't have your foot in it, you'll just be cruisin' so the converter clutch doesn't have to be extra beefy. Even then, if it's properly setup, the converter will unlock with heavy throttle.
[Re: John_Kunkel]
#1487036
08/20/13 08:55 PM
08/20/13 08:55 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I guess I should have said that I certainly do not expect the LU or the OD to hold any where near full power. It will only be for cruising along at light throttle.
As for requiring a master fabricator, there are adapter tranny mount brackets out there and I can surely cut the bell off of the 518 in preparation for bolting on the adapter bell. There are several very good and informative threads that will be invaluable for this.
A 518 core is $150 at the pick a part yards when they pull it, and I plan to test fit it before I spend the coin to beef it up. So if the wheels do fall off this project, I am not in up to my ears in it.
I am just curious about 2 things mainly; First, with 4,000 stall and 3.91s, will the cruise RPM be so low that there will be enough slip in the converter without LU to give me too much heat while cruising. Second, what would you guys run and why? LU or non LU. And if the LU, what are the restrictions that I would run into?
PTC has been building my converters and do a super job. I will talk to them also, but just wanted some opinions here first.
And if need be, I can back off the stall speed. We do not run the KOS circuit much any more. But would like to ready if it picks back up.
Thanks for the input, guys! I really appreciate it.
[Re: DaveRS23]
#1487037
08/21/13 05:08 PM
08/21/13 05:08 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
I am going to be running a 618 in my challenger. I have already cut off the bell. I am not sure if I am going lockup. The diesel converter is a lot larger than the 727 and with an ultra bell obviously we are going to have to run a stock size 727 converter. I have not done much research but I am not sure if there will be enough space to put clutch material to hold high hp applications.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: Jambbii]
#1487038
08/21/13 06:37 PM
08/21/13 06:37 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Be sure to slip in a gas engine governor if you haven't already. 3200 rpm shift points aren't much fun.
