Wiped Out My Cam What To Look For As Cause
#1486828
08/19/13 03:46 PM
08/19/13 03:46 PM
Posts: 550 Lakewood, Colorado
runnerrt
Lakewood, Colorado
Driving my Bee home from a show a couple weeks ago, I noticed a tapping in the engine. I tore it open this weekend and the #8 exhaust lifter is concaved and looks like the lobe is shot. The engine is a 383 with MP 509 cam that was built 23 years ago and has about 10k on it. I just put a set of MP aluminum 452's on it a couple months ago (300 miles), stock rockers with correct length push rods. I am going to pull it clean it out and put another 509 in it for now, until my 489 stroker is done. I do not want it to happen again, What possible causes should I look for? Thanks.
1969 Super Bee High School car I got back
2004 Ram 2500
Re: Wiped Out My Cam What To Look For As Cause
[Re: runnerrt]
#1486829
08/19/13 03:52 PM
08/19/13 03:52 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Could be that the new heads have spring pressure that is too high or some kind of interference or binding taking place.
You are using good flat tappet oil I assume.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: runnerrt]
#1486830
08/19/13 03:58 PM
08/19/13 03:58 PM
RapidRobert
poor metallurgy. not enouugh zinc. poor breakin procedure. lifter not free (enough) to rotate in it's bore. too high of spring psi on breakin. 23 yrs is a long time/alot of history
[Re: RapidRobert]
#1486831
08/19/13 04:03 PM
08/19/13 04:03 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
The MP 452's (straight plug Eddy's) have a spring rate compatible with the 509 cam. After all those years, I would have to guess that you didn't have enough zinc additive after the last oil change. I use 1/2 bottle Lucas break-in additive with Rotella diesel oil. So far; so good.
This is the land of the free
because of the brave
[Re: rbstroker]
#1486832
08/19/13 04:33 PM
08/19/13 04:33 PM
runnerrt
Lakewood, Colorado
I run Valvoline VR1 race oil, it claims to have high zinc content
2004 Ram 2500
[Re: RapidRobert]
#1486833
08/19/13 04:35 PM
08/19/13 04:35 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
considering all he did was swapp heads , and an oil change , a lot of those issues really wouldn't/couldn't/shouldn't apply.
Did you have the heads checked out before installing them or just ASSuME they were ready to go out of the box ?
[Re: Dcuda69]
#1486838
08/19/13 08:55 PM
08/19/13 08:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Did you measure the retainer to guide clearance at max lift? Just a thought.
