Wiped Out My Cam What To Look For As Cause #1486828
08/19/13 03:46 PM
08/19/13 03:46 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
Driving my Bee home from a show a couple weeks ago, I noticed a tapping in the engine. I tore it open this weekend and the #8 exhaust lifter is concaved and looks like the lobe is shot. The engine is a 383 with MP 509 cam that was built 23 years ago and has about 10k on it. I just put a set of MP aluminum 452's on it a couple months ago (300 miles), stock rockers with correct length push rods. I am going to pull it clean it out and put another 509 in it for now, until my 489 stroker is done. I do not want it to happen again, What possible causes should I look for? Thanks.
1969 Super Bee High School car I got back 2004 Ram 2500
Re: Wiped Out My Cam What To Look For As Cause [Re: runnerrt] #1486829
08/19/13 03:52 PM
08/19/13 03:52 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Could be that the new heads have spring pressure that is too high or some kind of interference or binding taking place.
You are using good flat tappet oil I assume.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Wiped Out My Cam What To Look For As Cause [Re: runnerrt] #1486830
08/19/13 03:58 PM
08/19/13 03:58 PM
poor metallurgy. not enouugh zinc. poor breakin procedure. lifter not free (enough) to rotate in it's bore. too high of spring psi on breakin. 23 yrs is a long time/alot of history
Re: Wiped Out My Cam What To Look For As Cause [Re: RapidRobert] #1486831
08/19/13 04:03 PM
08/19/13 04:03 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
The MP 452's (straight plug Eddy's) have a spring rate compatible with the 509 cam. After all those years, I would have to guess that you didn't have enough zinc additive after the last oil change. I use 1/2 bottle Lucas break-in additive with Rotella diesel oil. So far; so good.
This is the land of the free because of the brave
Re: Wiped Out My Cam What To Look For As Cause [Re: rbstroker] #1486832
08/19/13 04:33 PM
08/19/13 04:33 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
I run Valvoline VR1 race oil, it claims to have high zinc content
Re: Wiped Out My Cam What To Look For As Cause [Re: RapidRobert] #1486833
08/19/13 04:35 PM
08/19/13 04:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
considering all he did was swapp heads , and an oil change , a lot of those issues really wouldn't/couldn't/shouldn't apply.
Did you have the heads checked out before installing them or just ASSuME they were ready to go out of the box ?
Re: Wiped Out My Cam What To Look For As Cause [Re: JohnRR] #1486834
08/19/13 04:41 PM
08/19/13 04:41 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
After the horror stories I have seen on here,I had them checked out and was told everything was good.
Re: Wiped Out My Cam What To Look For As Cause [Re: runnerrt] #1486835
08/19/13 04:47 PM
08/19/13 04:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
In that case it was either the oil , doesn't take long for the lifter and cam nose to go away once the metal transfer starts , or the lifter stopped rotating , obviously , for some reason. New pushrods ? How much preload ?
Re: Wiped Out My Cam What To Look For As Cause [Re: runnerrt] #1486836
08/19/13 07:07 PM
08/19/13 07:07 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
after 23 years probably enough dry starts to start some cam wear then it all of the sudden goes like crazy!
Re: Wiped Out My Cam What To Look For As Cause [Re: Dodgem] #1486837
08/19/13 07:50 PM
08/19/13 07:50 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
My buddy lost his MP .528 solid after many years and many miles. He had not touched a thing and poof one day lobes gone bye-bye. Think strongly about a roller for your new build
Re: Wiped Out My Cam What To Look For As Cause [Re: Dcuda69] #1486838
08/19/13 08:55 PM
08/19/13 08:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you measure the retainer to guide clearance at max lift? Just a thought.
Don't be the exception.
Re: Wiped Out My Cam What To Look For As Cause [Re: JohnRR] #1486839
08/19/13 09:04 PM
08/19/13 09:04 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
They were Rhodes lifters And they call for at least .031 preload and prefered .0625 to .125 and the push rods were ordered for .0625
Re: Wiped Out My Cam What To Look For As Cause [Re: Rapid340] #1486840
08/19/13 09:13 PM
08/19/13 09:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
OIL or you have
or as other have said the lobe was weak, new spring pressure finished it off.
