Broke the Cam in the 512 at the Nostalgia Gold Cup #1486269
08/18/13 04:05 PM
08/18/13 04:05 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Well, we certainly didn't expect that. First pass, top of second gear, somthing let go, but the engine was still running. Took us a while to figure it out, but we lost the back of the cam...Pulled the engine out today. Might be going roller.....
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: Dragula] #1486270
08/18/13 04:28 PM
08/18/13 04:28 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Something was unhappy in the valvetrain.
Hope it didnt damage too much else...
RIP Monte Smith
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: CompWedgeEngines] #1486271
08/18/13 06:46 PM
08/18/13 06:46 PM
Dragula Offline OP
Dragula  Offline OP
The only other damage we were able to find were the lash caps. They took a beating. Just simply sheared the back of the cam off. Three seasons on that cam. The lifters lifted right out. Block looks good.
I am sure we need a new cam bearing though....
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: Dragula] #1486272
08/18/13 08:04 PM
08/18/13 08:04 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Looks like you need to take your motor to Todd and let him fix it.
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: 1967Valiant] #1486273
08/18/13 09:48 PM
08/18/13 09:48 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Check your spring pressures. I would bet you have some weak ones to cause an issue if it lived for three seasons
Keith
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: Dunnuck Racing] #1486274
08/18/13 09:53 PM
08/18/13 09:53 PM
Dragula Offline OP
Dragula  Offline OP
I was kinda thinking we should check them all. Got only two weeks, so we have a lot of work to do...
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: Dragula] #1486275
08/18/13 10:22 PM
08/18/13 10:22 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
You close enough to todd run it over to him let him hook you up!
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: 1967Valiant] #1486276
08/18/13 11:03 PM
08/18/13 11:03 PM
Dragula Offline OP
Dragula  Offline OP
I am not sure who Todd, is, but its down at Farley's and the parts will be ordered tomorrow. At least the parts we know we need. Going to a roller cam this time.
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: Dragula] #1486277
08/19/13 12:43 AM
08/19/13 12:43 AM
NC
1967Valiant Offline
1967Valiant  Offline
NC
http://www.competitionwedge.com
this help
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: 1967Valiant] #1486278
08/19/13 12:59 PM
08/19/13 12:59 PM
Dragula Offline OP
Dragula  Offline OP
this help
I met him briefly at NYIRP last year. Sorry, horrible with names.
Right now we are just looking to get a cam and a couple of push rods on order. Bearings and gaskets I think we have, and I am going to port match the intake to the heads while they are off. We might even put new rings and a quick hone on it, we will see. Springs also need to be checked, but they all looked fine, I didn't see any broken ones.
Re: Broke the Cam in the 512 at the Nostalgia Gold Cup [Re: Dragula] #1486279
08/19/13 01:20 PM
08/19/13 01:20 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had that happen several years ago on my 440 in my street Charger. Spun a cam bearing. Broke the cam just behind the #4 journal. Drove it home on 6 cylinders. Pulled the valve covers #7 & #8 rocker were not moving. Required a full rebuild though. Filled the filed with babbit material.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
