92 W150 front axle u-joint replacement procedure? #1485638
08/17/13 11:20 AM
08/17/13 11:20 AM
WI
61 NYer Convt Offline OP
WI
Hi guys. My front axle u joints are toast. Im having trouble finding any info on the procedure of changing the front axle u joints in the CAD dana 44 axle. Could someone please give some info on procedure, tools needed, parts (besides u joints) etc? any info is greatly appreciated.
Re: 92 W150 front axle u-joint replacement procedure? [Re: 61 NYer Convt] #1485639
08/17/13 12:28 PM
08/17/13 12:28 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Harder to explain than it is to do, but, press out the tie-rod, press out the ball joints and slide the axle out. Put in greasables for u-joints and stay on top of greasing them (like every 2000 miles or so). You have to be very careful installing the shaft into the axle tubes: if you hit the seal too hard it'll wind up leaking and the whole mess has to come apart again. Changing those inner axle seals is a truely miserable experience.
With the right key words you can find the procedure on "Pirate 4x4" or something like that.
That's it in a nutshell, get the large "C" clamp "4x4 front end tool kit" because it will make life easy for you. I can post a picture if you like.
Mo' Farts
Moderated by "tbagger".
Re: 92 W150 front axle u-joint replacement procedure? [Re: Grizzly] #1485640
08/17/13 12:47 PM
08/17/13 12:47 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
It's a 92, no special tools needed. Basically you take the rotors off then pull the axle out through the hub and change the u-joints. I can't remember but I think you pull the CAD off so you can guide the axle back into the sleeve.
Sheldon
Re: 92 W150 front axle u-joint replacement procedure? [Re: Grizzly] #1485641
08/17/13 12:57 PM
08/17/13 12:57 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Why would he tear it completely apart like you suggest?
Re: 92 W150 front axle u-joint replacement procedure? [Re: RUNCHARGER] #1485642
08/17/13 12:59 PM
08/17/13 12:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Sheldon
I always engage it in 4wd first. That way the CAD gear will stay in place on the intermediate shaft. About the only tool you will need is the wheel bearing nut 4 pronged socket.
Re: 92 W150 front axle u-joint replacement procedure? [Re: 61 NYer Convt] #1485643
08/17/13 01:00 PM
08/17/13 01:00 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
http://ramchargercentral.com/articles/?sa=view;article=86
The link is not a CAD but close enough- only yhe hub is different. You will need a special socket to get the lock nuts out of the hub- don't use the punch method. The tie rod ends and ball joints stay right where they are on a CAD- no need to touch. A big vise, press or 4x4 ball joint press will make things easier.
The place where most people screw up is putting things back together and adjusting the front wheel bearings properly. A FSM can help, or a copy may have been posted on RCC. If you do a alot of these, you can do it by feel, but a torque wrench helps.
Tools:
lock nut socket
1/2 extension and socket
torque wrench
pick or small screwdriver
c clip pliers (forget the proper name)
jack
safety stand
Lastly, watch where the pin for the internal lock nut is because most people don't know its there and ruin the whole set or the bearings back off and cause problems
This is not rocket science, easy to do. Good time to repack bearings at same time, in which case you'll need the inner bearing seal as well.
Re: 92 W150 front axle u-joint replacement procedure? [Re: NITROUSN] #1485644
08/17/13 01:08 PM
08/17/13 01:08 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Forgot about the 4 point socket, I take this stuff for granted most of the time.
Sheldon
Re: 92 W150 front axle u-joint replacement procedure? [Re: RUNCHARGER] #1485645
08/17/13 02:05 PM
08/17/13 02:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Sheldon
Before we had extra money for fancy sockets a punch or chisel was used to remove and install the nuts. [lol] Never had a manual or internet to do the job.
Re: 92 W150 front axle u-joint replacement procedure? [Re: 76dodgeboy] #1485646
08/17/13 05:35 PM
08/17/13 05:35 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Sorry 'bout that guys: I had play in my uppers and had to do them anyway. Pulled it apart to do two jobs in one.
Thanks for correcting, Sheldon.
Mo' Farts
Re: 92 W150 front axle u-joint replacement procedure? [Re: Grizzly] #1485647
08/17/13 11:11 PM
08/17/13 11:11 PM
WI
WI
Thanks for the replies guys. I'm gonna do it tomorrow. If I engage it in 4wd before taking it apart will I still need to pull the CAD off the axle?
Re: 92 W150 front axle u-joint replacement procedure? [Re: 61 NYer Convt] #1485648
08/17/13 11:48 PM
08/17/13 11:48 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That's it. Fire it up, throw lever in lock, making sure the light comes on on dash and shut truck off then, and you should be able to get through the job w/out removing the cad 4 bolts stuff.
