Dakota Drag Trucks please post pictures #1485391
08/16/13 10:50 PM
08/16/13 10:50 PM
Alabama
drag318 Offline OP
drag318  Offline OP
Alabama
Getting ready to start a Dakota build. Have a nice 1st generation but really wanting to find a standard cab short bed 3rd generation. Please post pictures of any you may have year doesnt matter. Need to start getting ideas. Thanks.
Re: Dakota Drag Trucks please post pictures [Re: drag318] #1485392
08/16/13 11:27 PM
08/16/13 11:27 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Dakota Drag Trucks please post pictures [Re: bigdad] #1485393
08/16/13 11:29 PM
08/16/13 11:29 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Now that will get you started with some ideas
Re: Dakota Drag Trucks please post pictures [Re: drag318] #1485394
08/16/13 11:39 PM
08/16/13 11:39 PM
PA
9
99yellaR/T Offline
99yellaR/T  Offline
PA
yes pics please very intrested in this topic! not a drag truck but do race it once in awhile...1999 Dakota R/T best so far 13.7's in good air
Re: Dakota Drag Trucks please post pictures [Re: rowin4] #1485395
08/16/13 11:40 PM
08/16/13 11:40 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
does it have to be a Dakota & does it have to be drags?
Re: Dakota Drag Trucks please post pictures [Re: drag318] #1485396
08/17/13 12:42 AM
08/17/13 12:42 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
It's a street truck - but it goes to the track once in awhile.
Re: Dakota Drag Trucks please post pictures [Re: Duner] #1485397
08/17/13 10:17 AM
08/17/13 10:17 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Awesome truck. Details please. Can you get a manual rack for the 3rd gen Dakota? What do they weigh? What size tire are you running without having to do any cutting?
Re: Dakota Drag Trucks please post pictures [Re: DaKuda] #1485398
08/17/13 11:37 AM
08/17/13 11:37 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Thanks!
I'm still running the power steering. I've heard talk of manual racks - but never seen a supposed manual rack from a '97 that's been reported. No cutting for tire clearances. Both front and rears now 29" tall. You could make one quite a bit lighter if you were making it a race only vehicle. I still want my ice cold AC and stereo.
Here is the full list of specs:
99 RC R/T
Stock block 2-bolt mains, stock bolts, no fill
.030 over Probe forged pistons 8.8:1
Eagle H-Beams Rods
Forged Scat Crank
Internally Balanced
2.02 EQ heads (home ported)
Cometic head gaskets
New stock head bolts
Comp cams 236° duration, .546"/.546", 114° lsa, retarded 4°
Mopar Performance springs
Mopar Performance titanium retainers
Crane Gold 1.6 aluminum roller rockers
Trick Flow pushrods
2 bbl M1 intake
F&B 50mm throttle body
Single 76mm turbo w/T4 .96 A/R turbine
CBE turbo header
CBE air/water intercooler airhat
Ebay blowoff valve
Tial 44mm wastegate
4" downpipe to 4" Hooker Morflow muffler
MSD 6AL ignition with Blaster coil
MSD 8.5mm wires
Autolite 3923 plugs
MS3X Standalone control
66# injectors
KB boost-a-pump
Holley 12-922 forced induction intank pump
MSD inline booster pump
Built trans with transgo shift kit
Precision Industries Viper 4,000 stall convertor (flashes to 4800 with full boost)
3.92 rearend with Detroit Locker
Jeep Cherokee Rear Disk Brake conversion
Trick front springs
QA-1 Single Adjustable front shocks
CalTracs with Monoleaf springs - extended rear arms
Calvert Racing rear shocks
Hoosier 29x12.5x15 slicks
Bogart rims
MT 29x4.5 ET Fronts
Fiberglass front bumper and rollpan
Twin 11" electric fans
RCI Trans Blanket
Driveshaft Loop
Summit SFI Balancer
5-Point Rollbar
Simpson 5-Point SFI Belts
4-Gallon fuel cell for Intercooler Ice system
Probably down to a race weight of 4000# - haven't weighed it in a while
Best pass so far was a 10.61 @ 133 mph with a horrible 1.7X something 60'.
Last pass down the track was a 10.72 @ 126 mph with a 1.43 60' time on much less boost. The coulda, woulda, shoulda line is that turning the boost back up should net a pretty low 10-second timeslip. I'll believe it when I have the slip. LOL
Re: Dakota Drag Trucks please post pictures [Re: drag318] #1485399
08/17/13 04:08 PM
08/17/13 04:08 PM
monticello,ms
andy3965 Offline
Happy Birthday andy3965  Offline
monticello,ms
88 DAK with a 394ci W2 headed stroker smallblock.
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: Dakota Drag Trucks please post pictures [Re: drag318] #1485400
08/17/13 05:22 PM
08/17/13 05:22 PM
MD
ADakotaRTGuy Offline
MD
Couple pictures from mine. Been 10.70 on the first run on nitrous. Next run i put to much air in and spun, never had a chance to take it out again after tweaking the tune. Went 11.25 on motor. 440 small block with a 727. Has more in it, but the motor is really low compression 9:1, was originally supposed to be a turbo motor.
I do have manual steering on it. Its a flaming river rack with adapters and the control arms have heim joints at the control arms.
Re: Dakota Drag Trucks please post pictures [Re: ADakotaRTGuy] #1485401
08/17/13 10:47 PM
08/17/13 10:47 PM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
My dakota is a 1990 with a R/t headed 360 magnum in it. It runs 12.20s on motor and 10.90s on nos.
http://i909.photobucket.com/albums/ac293/mphsmitch/1990%20dodge%20dakota/kelstruck2-1.jpg
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
