Liberty shifted 18 spline problem? #1485200
08/16/13 02:30 AM
08/16/13 02:30 AM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Hey all, just bought me a liberty trans here not to long ago from another guy. I'm new to these, anyways finally got it in the car. The problem I'm having is it won't stay in third gear, every gear works great. Not sure were to look, adjusted it a bunch of times. Anyways I thought I'd ask here first.
Thanks!
Re: Liberty shifted 18 spline problem? [Re: Z_Z] #1485201
08/16/13 03:44 AM
08/16/13 03:44 AM
Take the shifter lever off of the tranny side cover and see if the rectangle on the shift arm is worned so it is not square on the ends that the shift lever fit onto If so that may be the problem or part of the problem If not look remove the side cover and look to see if it is a early cover with rooster combs and brass shifting forks or the later one with the GM style cover with steel shifting forks. If it is the early one make sure the check balls, one on each side of the srping are in place, also look at the half moons that the check balls ride in. If those check out good the last thing that can cause what your having is the slider and the engagement rings on third gear being worn,not uncommon Or maybe the snap ring that holds the synchro hub on the main shaft (output shaft) is loose or missing Lots of gremlins out there, especially on used race parts Good luck, let us know what you find. BTW,I had a set of gears that I had to hold the shifter in third gear or it would pop out I ended up having it redone(new engagement ring on it, and put a new slider in the box and that fixed that 3-4 gear set
Re: Liberty shifted 18 spline problem? [Re: Cab_Burge] #1485202
08/16/13 08:51 AM
08/16/13 08:51 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
When the slider and the rings are at the end of their life span they pop out of gear. At WOT its real fun. If all adjustments are good its time to go back to Liberty to get "Face Plated" Don't waste any more money on "Pro Shifting" It is a thing of the past
Re: Liberty shifted 18 spline problem? [Re: scatpacktom] #1485203
08/16/13 01:54 PM
08/16/13 01:54 PM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
I understood with a pro shifted trans you have to hold in gear or it will fly out of gear, nature of the beast .The advantage of the faceplate was they would not pop out of gear. aAuded to on the Liberty site
Re: Liberty shifted 18 spline problem? [Re: Z_Z] #1485204
08/16/13 02:36 PM
08/16/13 02:36 PM
MN
hemidup Offline
hemidup  Offline
MN
I recently rebuilt an 833/18 spline using brand new Liberty parts. I had the same issue. The trans would pop out of 3rd gear. After pulling the trans out 7 times and tearing it down on the bench to make sure I didn't mess up, I was at wit's end. I then called friends Herb McCandless(Mr. 4 speed)and Arlen Vanke for advice. Both told me to lightly loosen the side cover bolts and smack the right rear corner of the side cover upwards with a hammer and retighten the bolt's. Dang if that didn't work.
Jerry Williams.
Re: Liberty shifted 18 spline problem? [Re: RTshaker] #1485205
08/16/13 05:04 PM
08/16/13 05:04 PM
Not true when all parts are good Sounds like Liberty wants to sell the new technology now
Re: Liberty shifted 18 spline problem? [Re: Cab_Burge] #1485206
08/16/13 05:10 PM
08/16/13 05:10 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
you should not have to hold a pro shift in gear, if its a used trans probably needs a new proshift ring. they wear out and when there's not enough material left they will do that.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Liberty shifted 18 spline problem? [Re: 68 HEMI GTS] #1485207
08/16/13 05:14 PM
08/16/13 05:14 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
this is what a fresh proshift looks like
Re: Liberty shifted 18 spline problem? [Re: 68 HEMI GTS] #1485208
08/16/13 06:41 PM
08/16/13 06:41 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
When those rings are used up there is no holding it in gear! It'll tear your arm out of its socket.
I've tried to get "one more pass" and when they are done they're done
Re: Liberty shifted 18 spline problem? [Re: scatpacktom] #1485209
08/16/13 09:53 PM
08/16/13 09:53 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
face plating only way to go. I have one of each an the pro shifted one will not stay in third evin holding a 1970 pistlegrip it still pops out.
The gear an slider are bad.
A face plated trans next best thing to autotrans
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Liberty shifted 18 spline problem? [Re: 1969gtx] #1485210
08/16/13 11:39 PM
08/16/13 11:39 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If the ring looks good, the slider is worn out. As said in the other post , go face plate. Cost is the same for replacement. I've never had a problem with 3 rd gear kicking out, always 4th.
Re: Liberty shifted 18 spline problem? [Re: 1969gtx] #1485211
08/16/13 11:44 PM
08/16/13 11:44 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Ugh guys, not the news I'm wanting to hear, looks like I'm going to be pulling the trans out and go from there.
Re: Liberty shifted 18 spline problem? [Re: rowin4] #1485212
08/16/13 11:47 PM
08/16/13 11:47 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
If I face plate it, does the whole trans got to go back to liberty? Any idea on cost?
Re: Liberty shifted 18 spline problem? [Re: Z_Z] #1485213
08/17/13 12:13 AM
08/17/13 12:13 AM
Learn how to take that trans. apart and reassemble it , It's not that difficult You will need to take the input shaft(4th gear) and the 3rd and 2nd gears off of the main shaft to have them done, leave 1st gear stock with the brass synchro ring on it and grind the little engagement teeth off of the brass ring and maybe the end that is away from the end with the teeth on it so you can put it in first gear with out shutting the motor off and having the stop the car to put in it 1 st gear after a run Not sure about face plated boxes, I never ran one of them
Re: Liberty shifted 18 spline problem? [Re: Z_Z] #1485214
08/17/13 12:29 AM
08/17/13 12:29 AM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
I had Liberty faceplate 2nd, 3rd, and 4th. It was about $80/per gear, but you'll also need new sliders ($125/ea?). They have a new slider/fork setup that allows 1st gear to stay as a synchro. I took the whole trans apart and just shipped what they needed.
My order was over $600.00 but I had them do alot more stuff like rebuild the side cover, cryogentically(sp?) treat all the internals, etc. Call and talk with them, nice folks. May take awhile, mine was 8 week turn around.
In the pic, the old syncro sliders are in the bottom right for comparison.
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: Liberty shifted 18 spline problem? [Re: 6pak2go] #1485215
08/17/13 01:11 AM
08/17/13 01:11 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Call and talk to Paul. He does all the "old" trannys. I had my trans gears face-plated this past winter. Wow what a differance from a pro-shifted trans to a face-plated one. Whole new world. Especially on the street. Ship them the whole trans and let them go to town. It costs $$$$, but it is worth it in the long run. The little extra stuff they do is unreal. Plus I needed a lot of parts. This is what it looked like before I shipped it out. If I can find the picture.
Re: Liberty shifted 18 spline problem? [Re: 70HemiGTX] #1485216
08/17/13 11:54 AM
08/17/13 11:54 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
like stated the face plated route is the way to go, its much more street and downshift friendly. last time i did one they were not able to faceplate second yet so i only had it on 3&4. their super easy to work on if you have a press.
Re: Liberty shifted 18 spline problem? [Re: 68 HEMI GTS] #1485217
08/17/13 07:30 PM
08/17/13 07:30 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Wow guys thanks for the wealth of information, greatly appreciated! I'll get at it here sometime and take it apart,I had my last one apart so I hope it's not too bad.
Zak
Re: Liberty shifted 18 spline problem? [Re: Z_Z] #1485218
08/17/13 09:14 PM
08/17/13 09:14 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Plus the face plated gears are MUCH EASIER to shift. (In my opinion.) When driving on the street you have to drive it like an old truck. The basic old 2-second shift. But when on the track, it shifts much faster and easier. Sounds like an auto.
