Re: Liberty shifted 18 spline problem?
[Re: Z_Z]
#1485201
08/16/13 03:44 AM
08/16/13 03:44 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
Take the shifter lever off of the tranny side cover and see if the rectangle on the shift arm is worned so it is not square on the ends that the shift lever fit onto If so that may be the problem or part of the problem If not look remove the side cover and look to see if it is a early cover with rooster combs and brass shifting forks or the later one with the GM style cover with steel shifting forks. If it is the early one make sure the check balls, one on each side of the srping are in place, also look at the half moons that the check balls ride in. If those check out good the last thing that can cause what your having is the slider and the engagement rings on third gear being worn,not uncommon Or maybe the snap ring that holds the synchro hub on the main shaft (output shaft) is loose or missing Lots of gremlins out there, especially on used race parts Good luck, let us know what you find. BTW,I had a set of gears that I had to hold the shifter in third gear or it would pop out I ended up having it redone(new engagement ring on it, and put a new slider in the box and that fixed that 3-4 gear set
[Re: Cab_Burge]
#1485206
08/16/13 05:10 PM
08/16/13 05:10 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
you should not have to hold a pro shift in gear, if its a used trans probably needs a new proshift ring. they wear out and when there's not enough material left they will do that.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: scatpacktom]
#1485209
08/16/13 09:53 PM
08/16/13 09:53 PM
Posts: 643 southern conn
1969gtx
southern conn
face plating only way to go. I have one of each an the pro shifted one will not stay in third evin holding a 1970 pistlegrip it still pops out. The gear an slider are bad. A face plated trans next best thing to autotrans
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: 1969gtx]
#1485210
08/16/13 11:39 PM
08/16/13 11:39 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
If the ring looks good, the slider is worn out. As said in the other post , go face plate. Cost is the same for replacement. I've never had a problem with 3 rd gear kicking out, always 4th.
[Re: Z_Z]
#1485214
08/17/13 12:29 AM
08/17/13 12:29 AM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
I had Liberty faceplate 2nd, 3rd, and 4th. It was about $80/per gear, but you'll also need new sliders ($125/ea?). They have a new slider/fork setup that allows 1st gear to stay as a synchro. I took the whole trans apart and just shipped what they needed.
My order was over $600.00 but I had them do alot more stuff like rebuild the side cover, cryogentically(sp?) treat all the internals, etc. Call and talk with them, nice folks. May take awhile, mine was 8 week turn around.
In the pic, the old syncro sliders are in the bottom right for comparison.
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: 70HemiGTX]
#1485216
08/17/13 11:54 AM
08/17/13 11:54 AM
68 HEMI GTS
Temperance, MI
like stated the face plated route is the way to go, its much more street and downshift friendly. last time i did one they were not able to faceplate second yet so i only had it on 3&4. their super easy to work on if you have a press.
