'78 truck water valve Q. #1485196
08/16/13 02:24 AM
08/16/13 02:24 AM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
On a '78 truck is it possible for the water (heater) valve to go beyond closed and actually open up again?
The cable popped off mine and I thought I had closed it by hand but the inside of the truck was still overly warm compared to outside air. Yes, I had the fresh air door in the kick panel open.
Which way is closed? All the way forward or all the way back toward the firewall? I hate working on this type of problem with only one set of eyes.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: '78 truck water valve Q. [Re: Cheeto] #1485197
08/16/13 02:57 AM
08/16/13 02:57 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
When the cable is Pushed out the knob is to the left which is the cool side. So with that said the cable should be pushing it closed. I cant really picture the valve off hand. Hope that helps
Re: '78 truck water valve Q. [Re: 76dodgeboy] #1485198
08/16/13 12:56 PM
08/16/13 12:56 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
You may need to replace it...I had that issue with my 76, it eventually wore a hole thru the "closed" portion of the valve, and it wouldn't completely close after that. New valve (less than $10 at NAPA) fixed it. I *think* it's closed when the top is all the way AWAY from the firewall, and OPEN when it's pointed close to the firewall. But, I'm not looking at my 76 right now, so...? You should be able to tell full open from part open by temp pretty easily. Good luck! If it were me, I'd probably just pull it off and see...
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: '78 truck water valve Q. [Re: AdventurerSport] #1485199
08/18/13 01:07 AM
08/18/13 01:07 AM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
You guys are right...closed when the arm on the valve is forward. My cable must've slid in the retainer at the valve too because it wasn't traveling far enough to close the valve all the way.
Thanks!
Cheeto
It's not perfect.
It's not correct.
It's not yours!
