You may need to replace it...I had that issue with my 76, it eventually wore a hole thru the "closed" portion of the valve, and it wouldn't completely close after that. New valve (less than $10 at NAPA) fixed it. I *think* it's closed when the top is all the way AWAY from the firewall, and OPEN when it's pointed close to the firewall. But, I'm not looking at my 76 right now, so...? You should be able to tell full open from part open by temp pretty easily. Good luck! If it were me, I'd probably just pull it off and see...
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
