68 Charger Vacuum line grommet reproductions? #1484487
08/14/13 03:36 PM
08/14/13 03:36 PM
Northeast MA
Charger446 Offline OP
Northeast MA
Anyone reproduce the rubber firewall grommet where the vacuum lines pass through on 68 or 69 Charger? I was looking at mine yesterday and it is very worn, enough to have engine compartment fumes pass through as I poked a few smaller holes to wire God knows what 10 years ago. I know I can probably find a body plug the same size and drill some holes but I dont want it to look like I did just that. I researched it a bit on line but couldnt find what I was looking for. Anyone know if its being reproduced? If not any tips on making a clean job of a universal grommet? Thanks!
Re: 68 Charger Vacuum line grommet reproductions? [Re: Charger446] #1484488
08/14/13 04:10 PM
08/14/13 04:10 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Can you post a picture of one? I might have one or two in a box with old wiring harness/vacuum hose stuff back in the garage.
Re: 68 Charger Vacuum line grommet reproductions? [Re: 68jim] #1484489
08/14/13 04:36 PM
08/14/13 04:36 PM
Northeast MA
Northeast MA
Thanks Jim, I couldnt find on on line and mine is at home, here is one thats very close, but the one I need has 3 holes.
Re: 68 Charger Vacuum line grommet reproductions? [Re: Charger446] #1484490
08/14/13 05:15 PM
08/14/13 05:15 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Got it - I'll check as soon as I get home this afternnon.
Re: 68 Charger Vacuum line grommet reproductions? [Re: 68jim] #1484491
08/15/13 09:52 AM
08/15/13 09:52 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
No luck on the part. I was pretty certain I had one or two since I had parted out a few Chargers many years ago. I did find a two hole one like in the picture. I hope someone else will check their stash and help you out.
Good Luck,
Re: 68 Charger Vacuum line grommet reproductions? [Re: 68jim] #1484492
08/15/13 11:57 AM
08/15/13 11:57 AM
Northeast MA
Northeast MA
No worries Jim, really appreciate you checking though!
Mike
