A body rear spring segment length Q, SS vs std
#1484324
08/14/13 11:15 AM
08/14/13 11:15 AM
RapidRobert
Will going from one type to the other move the rear axle forward or rearward (which spring/which way & how far). Superstock 003. Thank you for your time.
Re: A body rear spring segment length Q, SS vs std
[Re: RapidRobert]
#1484325
08/14/13 11:29 AM
08/14/13 11:29 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
For an A body, I do not believe so.
[Re: 3ddart]
#1484336
08/15/13 09:46 AM
08/15/13 09:46 AM
RapidRobert
I have 2 A bodies, one with the SS springs & I have spaced them back at the front and also a plate at the rear so the bottom of the shackles is pointing rearward. rear ujoint end play is tight but acceptable. The other A body has OE springs with no spacers & there's a bit too much ujoint end play since the driveshaft is a little too short tho there is no vibration. I am swapping rear ends between the two & was considering swapping the springs also mainly for the ride & I was wanting to get an idea of the "on paper" differences between the two so I dont get jambed up on the ujoint end play deal. I was gonna just measure with a plumb bob/tape but the arch confused things so I thought I'd post. I may have to go ahead & measure (always a smart move ) & go from there. Thanks guys!
[Re: RapidRobert]
#1484337
08/15/13 12:56 PM
08/15/13 12:56 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Unless you have an early B body that the SS are 1 inch shorter.Frt segment on my 65 is 21 inches.Rocky
Chrysler Firepower
