Re: Question on fender mounted turn signals & inside arrows
[Re: Birdlover]
#1484302
08/14/13 11:00 AM
08/14/13 11:00 AM
RapidRobert
I'd think there'd have to be lamp holders for the bulb on each side to light up the 2 green arrows. But you wouldn't think both of em would have come undone & fallen out
[Re: RapidRobert]
#1484303
08/14/13 11:41 AM
08/14/13 11:41 AM
Posts: 70 ND
Birdlover
ND
The wiring harness is as neat as the day it left the factory. The bulb holders for oil pressure light and high beam are plugged in where they are suppose to be. There is just no bulb holders anywhere for the L & R signal arrows (there are holes for them in the cluster panel). I'm stumped!
1969 Road Runner, B7 Blue, 383, Auto
[Re: Birdlover]
#1484304
08/14/13 12:02 PM
08/14/13 12:02 PM
Posts: 2,190 SW MO
closer9
SW MO
Are they powered by the circuit board? I know my '67 B-body ones are. They are just the little plastic pieces that twist into the board. It's possible he just didn't like the inside signals and pulled them out.
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
[Re: Birdlover]
#1484305
08/14/13 12:15 PM
08/14/13 12:15 PM
Posts: 374 Alberta, Canada
300rag
Alberta, Canada
In 1965 at least on Chryslers, when fender mounted turn indicators were ordered, the dash indicators were disabled. It was one or the other.
Peter
'65 300 'vert 413/4spd '18 Challenger R/T Shaker '19 Durango R/T
[Re: Birdlover]
#1484306
08/14/13 12:19 PM
08/14/13 12:19 PM
Posts: 70 ND
Birdlover
ND
I don't believe they are powered by the circuit board. The other two aren't. Also, all the holes for the bulb holders are stamped with the wire color. The oil pressure and high beam bulb holders have the correct color wires going to them. The missing holes are stamped tan and green and these color wires are no where to be found.
[Re: 300rag]
#1484307
08/14/13 12:47 PM
08/14/13 12:47 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
Correct. All Mopars that came with the fender mounted turn signals did not have a provision for the dash turn signals to work. I tried to add the bulbs and holders along with the fender signals and they wouldn't work. Even stopped the fender signals from working. I know this because I have had a 66 Chrysler 300 and now my 66 Plymouth Satellite with the fender signals. It is either/or but not both....
[Re: 300rag]
#1484310
08/14/13 09:58 PM
08/14/13 09:58 PM
Posts: 6,516 Santa Cruz, California
Lefty
My 66 Chrysler 300 had bulbs in the fender sockets, no bulbs in the dash sockets.
[Re: notforsale440]
#1484311
08/14/13 10:12 PM
08/14/13 10:12 PM
Posts: 1,978 USA
Suregrip391
USA
been a while, but I think I remember the back of the cluster arrows had tape over them on my 68 GTX with fender mounted turn signals.........
I had a survivor 70 sport satellite with fender signals, the in dash arrows did not work, I pulled the dash out and there was factory black tape over the holes. Not knowing any better I removed the tape, inserted sockets with bulbs and both worked together.
[Re: Suregrip391]
#1484312
08/14/13 10:33 PM
08/14/13 10:33 PM
Posts: 162 nj
notforsale440
nj
yup....just looked at my cluster, first time in quite a while, lol............yes, black electrical type tape; keeps light from coming through the hole but also covers the bare copper connection on the circuit board......... I see no reason inserting bulbs wouldn't work
[Re: Birdlover]
#1484313
08/14/13 10:37 PM
08/14/13 10:37 PM
Posts: 19,408 north of coder
moparx
tan and green may correspond to the ts switch colors.
[Re: Ramrod39]
#1484315
08/15/13 01:49 AM
08/15/13 01:49 AM
Posts: 4,796 Castlegar, BC, Canada
That AMC Guy
I've had several cars with fender-top turn signals. A '68 New Yorker, a '71 Swinger and a '75 Valiant Brougham. In all cases, both dash and fender-top lights worked in unison. This is actually the first I've heard of the one or other situation.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
