Rollerized 904? #1484282
08/14/13 07:48 AM
08/14/13 07:48 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Does anyone have the part numbers or dimensions for any of the bearings required?
Thanks in Advance
Alan Jones
Re: Rollerized 904? [Re: LA360] #1484283
08/15/13 10:47 AM
08/15/13 10:47 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Most of the roller thrust bearings are the GM TH350 Pump stator bearing 1976-86, Delco P/N 9436851, OD=2.900", ID=2.110", thk=0.140". You can also buy this from www.bulkpart.com, P/N 44211C. Please double check with tech dept. This bearing is used in front and back of the rear planetary, rear of front planetary, rear of pump/front of front drum. The bearing in between the forward drum (input shaft drum) and direct drum, and the bearing in front of the front planetary and annulus gear are different.
Needle bearing thrust between forward clutch drum with input shaft and direct drum. This one is like the TH350 pump bearing, where the races are crimped together, making it an assembly rather than separate races and a needle cage.
OD=2.596"
ID=1.930"
Thk=0.140"
Sorry, I don't have a Torrington part number for this one. It is probably used inside a torque converter or another brand transmission. www.sonnax.com is a good place to start for searching thrust bearings.
This bearing requires no machining on the forward clutch drum with shaft. Rather, machining the back edge of the front drum, where it normally rides on the phenolic washer, is where you cut to make up room.
The front planetary (2.74 1st) uses two bearings in the assembly. And a 3rd between the back of the front planetary and front of the sun shell is the TH350 pump bearing.
Front of front annulus gear under snap ring:
OD=2.187" Torrington NTA-2435 (needle cage)
ID=1.500"
Thk=0.031" (race washers) Qty 2 Torrington TRA-2435
These are positioned under the snap ring in front of the annulus gear. The needle cage is sandwiched between the two thrust washers.
The thrust bearing in front of the front planetary and behind the front annulus:
OD=3.250" Needle cage, P/N NTA-4052
ID=2.500"
Thk=0.031" Thrust washers,P/N TRA-4052 Qty 2
The front of the front planet is machined to accept the extra thickness of the needle cage and two thrust washers. The pinion axle shafts are hardened, so there is evidence of using a carbide bit to grind the pins down. Then, the front face is machined down in a lathe.
Be sure to measure everything well before cutting. Always mock up with stock thrust washers, measure, then take into account new bearing thicknesses, and a tighter gear train endplay when final assembly is ready. You want the total gear train end play between 0.008"-0.015". The thrust bearing in front of the sun shell is captured behind the sun gear. Since the 2.74 low (front half of sun gear) is larger than rear, I believe the sun gear is ground some to allow the bearing to fit behind the gear.
The back of the front planet is machined for the thrust bearing, but the cut does not interfer with the pinion axles, just right up to the edge of the pins. Unlike the front of the front planet and both sides of the rear, where the machine cut is right into the axle pins. You would have to use a carbide cutter to cut thru pins because of their hardness. Maybe a ceramic bit or something specialized can do the job. I am not a machinist, just a hobbyist learning as I go.
Also, the most gains would be installing bearings in the gear train. I listed bearings between the pump and drums, but since there is little axial thrust here, the gains would be small. Although JPT fully rollerized the 904 in my case. Let me know if you need any other info.
The enclosed (crimped) bearings are harder to find info on. There is some good info on www.sonnax.com concerning crimped bearings, but sometimes when they list the part number, they don't show the dimensions. GM had Torrington or other companies make bearings for their converters & trannies, and some info is proprietary. The bearings are not labeled with a part number. The only thing you can do is measure the OD, ID, and thickness, and hopefully find some info on it. The one bearing between the clutch drums in my 904, I have not been able to find any info about it.
Concerning the aluminum planetaries (2.45 1st gear), they have different dimensions on the front hub. I have some in the garage, but have only a 2.74 set rollerized.
The rear support and low/rev drum - For the rear support, I have found another bearing brand, INA SCE, with similar part numbers. I bought some from
http://www.kamandirect.com/branches.asp
These bearings have a roller inner race along with the needle bearings. I believe they are rated with a higher capacity.
Concerning the seals in the rear support. I have seen some roller supports with and some without. The JPT, Dynamic, Turbo Action do not use seals. A&A does. I have an A&A roller support for a 727 that has a seal on the forward end. Here is a pic link:
http://www.hemiduster.com/crt_trans.htm
The low/rev drum hub is machined off. The rear side is bored to accept the bearing, which may or may not hang out the back a little. Looking from the side, the bearing does cover the oil supply hole from the rear cooler line in the case. Also, the front of the park gear is clearanced for the bearing. Plug the small hole in the front of the park gear and the angled hole into the sealing ring corner. The front of the support is bored to accept the seal (may or may not be the same as the bearing bore). Use the sealing ring on the park gear to seal the rear. Some machine off the front sealing ring groove up to the second for bearing room and weight reduction.
904 rear support would use a Torrington B-2110 bearing, or if you want the HD bearing, buy from INA SCE. The output shaft needs to be ground from 1.332" to 1.312" to use this bearing. If you want to rollerize the low/rev drum, you need to make a reducer bushing to fit into the drum so that the bearing (B-2110) will be held snug.
If you have more questions or need pics, send me an e-mail or PM. Glad to help.
John
Re: Rollerized 904? [Re: DusterW2] #1484284
08/15/13 12:45 PM
08/15/13 12:45 PM
dogdays Offline
dogdays  Offline
THIS needs to go into the Tech Archives.
R.
Re: Rollerized 904? [Re: dogdays] #1484285
08/15/13 01:00 PM
08/15/13 01:00 PM
Renton Washington
Triple Threat Offline
Renton Washington
R.
Awesome answer!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Rollerized 904? [Re: DusterW2] #1484286
08/15/13 01:35 PM
08/15/13 01:35 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
That is some GREAT information !!! Thanks for sharing!!
Does anyone have the same info for a 727???
Re: Rollerized 904? [Re: DusterW2] #1484287
08/15/13 08:01 PM
08/15/13 08:01 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Re: Rollerized 904? [Re: LA360] #1484288
08/15/13 11:44 PM
08/15/13 11:44 PM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
Al,
your local Statewide Bearing Co should have
this
koyo FH-48906
Re: Rollerized 904? [Re: cagebob1] #1484289
08/16/13 12:28 PM
08/16/13 12:28 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
The Rollerized 727 info is basically the same. I have an Excel file I made up with the differences. I can post later tonight.
The roller rear support uses a larger bearing, but you do not have to grind the output shaft. Uses an off the shelf Torrington, B-2420-oh (oh = oil hole in outer shell) if you do not rollerize the low/rev drum. There are several ways to do this and an encased seal can be installed in front of the support. Seen different configurations using the B-2410 & B-2416. The 2420 is the longest bearing and can still fit a seal in front. 440Jim and John Kunkel had posts with pictures. If you cut off the low/rev drum hub off, you have to use a narrow bearing. The B-2410 with no oil hole is used in the low/rev drum with reducer bushing and also in the support. It will hang out the back a little, so you have to clearance the front of the park gear to fit.
The rear planetary will use the TH350 pump bearings front & rear. The front planetary can use either a TH350 bearing at the rear of the annulus gear or two raceways and a needle cage. Also, use the 3 piece set-up between the rear of the front planet and the front of the annulus gear.
The drums and pump are a little more difficult because they require larger bearings, and typically they are thicker (~0.190") and you have to machine more to get them to fit. Most builders only rollerize the gear train because of the axial thrust produced from the helical gears. There is not much axial thrust between the drums and pump. It would be a good idea to simply keep end play clearances close to minimum to keep drums aligned.
Re: Rollerized 904? [Re: DusterW2] #1484290
08/16/13 01:27 PM
08/16/13 01:27 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Is it possible to do a diagram with part numbers so some of us can picture the actual layout of all of the different bearings? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Rollerized 904? [Re: DusterW2] #1484291
08/16/13 03:23 PM
08/16/13 03:23 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
Thanks for the info Any idea how much difference could be expected when going to a rollerized trans?
Re: Rollerized 904? [Re: cagebob1] #1484292
08/16/13 03:49 PM
08/16/13 03:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine was rollerized by Darrell Parks years ago but have no back-2-back numbers..........
Re: Rollerized 904? [Re: DusterW2] #1484293
08/17/13 12:06 AM
08/17/13 12:06 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
727 roller thrust bearings -
Pump/Direct drum GM-N-17
Direct Drum/Forward Drum GM-N-11
Front Planet (Between annulus
Gear & sun shell)
NTA 4860 Needle Cage
TRA 4860 Washer .031"
TRB 4860 Washer .060"
Front Planet (Between planet
Carrier & fwd surface of annulus
gear)
NTA 4052 Needle Cage
TRA 4052 Washer .031"
Rear Planet (Front) GM-N-14H
Rear Planet (Rear) GM-N-14H
Rear Support w/o roller drum
B-2416-oh
Encased Seal CR-14810
Rear Support w/ roller drum
INA SCE-2410
Encased Seal CR-14857
Low/Reverse Drum bearing B-2410
Low/Reverse Drum bushing:
OD 2.165”
ID 1.874”
Width 0.625”
Re: Rollerized 904? [Re: LA360] #1484294
08/17/13 12:10 AM
08/17/13 12:10 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Re: Rollerized 904? [Re: cagebob1] #1484295
08/17/13 10:24 PM
08/17/13 10:24 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I bought a full roller 727 and swapped it in to replace a non roller 727 and saw zero difference in ET, with a sorted out combo.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Rollerized 904? [Re: B3422W5] #1484296
08/17/13 10:28 PM
08/17/13 10:28 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
WOW...if that's the norm, why would anyone rollerize there trans?
Re: Rollerized 904? [Re: cagebob1] #1484297
08/17/13 10:32 PM
08/17/13 10:32 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Longevity? Durability? To be like Brand X?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Rollerized 904? [Re: cagebob1] #1484298
08/17/13 10:42 PM
08/17/13 10:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It is the norm. Been a number of threads on here over the years discussing this.
In fact when I bought the trans it was built with an aluminum drum and lightened sun shell as we'll. Still zero ET gain from a stock tranny with just hipo rebuild parts in it. Ran the two different trannies on back to back weekends actually.
It does make for reliability improvements though.
Edit..... Next time I will start with a well built 904 where I know there is a significant ET benefit over a 727
1.41 best 60 foot
6.56 at 104.17
Re: Rollerized 904? [Re: B3422W5] #1484299
08/18/13 11:28 PM
08/18/13 11:28 PM
LA360 Offline OP
LA360  Offline OP
Thanks for the replies, John, I will be in touch at some stage, probably closer to Christmas.
Thanks again
Alan Jones
Re: Rollerized 904? [Re: LA360] #1484300
08/21/13 09:29 AM
08/21/13 09:29 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
