74 duster no crank #1484270
08/14/13 02:33 AM
08/14/13 02:33 AM
IL,USA
bdusted440 Offline OP
IL,USA
ok so the owners manual says the seat belt has to be hooked in before she will crank.there is a relay on the apron that is for it.the om says to push the center of the tube in on it to crank without the seat belt being connected for service use. I tried it doesn't work.I used my remote start button and it fires right up.I also noticed it has no neutral safty switch on the trans.Where does it pick up the reverse lights.? Does any body have a wiring schematic for a 74 gold duster? I need to track this down.Seems like a funky setup.I have no signal at the starter relay.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
1970 v code superbee
Re: 74 duster no crank [Re: bdusted440] #1484271
08/14/13 10:45 AM
08/14/13 10:45 AM
www.mymopar.com would have the schematics for you. The backup light switch would have to be either on the side of the trans or on the shifter if it's a floor shifter. For the no crank the quickest would be to run a wire from the "start" terminal on the dangling connector under the steering column out to the "ign" terminal on the starter relay the one with the yellow wire on it. That'd bypass all of the nonsense then for the NSS either permanently ground the "grn" terminal on the starter relay if you're comfortable with that or make sure the wire downstream from there has continuity to ground in park/neutral thru the NSS wherever it is located (trans or clutch) or maybe shifter I would imagine
Re: 74 duster no crank [Re: RapidRobert] #1484272
08/14/13 02:16 PM
08/14/13 02:16 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
It sounds like the plug from the wiring harness to hook to the transmission (NSS) indicater is missing. There should be a 3 prong rubber plug connected to the trans in 1974.
...FAFO...
Re: 74 duster no crank [Re: skicker] #1484273
08/14/13 05:42 PM
08/14/13 05:42 PM
IL,USA
IL,USA
that's what I thought but the trans doesn't have one and no broken or unplugged wires.and it cranked fine until now.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
Re: 74 duster no crank [Re: bdusted440] #1484274
08/14/13 06:15 PM
08/14/13 06:15 PM
IL,USA
IL,USA
and the wiring schematic ive found doesn't show this system.yellow wire goes to the seatbelt relay then too a box on the pass side firewall.the reverse light wires run from the seat belt relay thing.from the box to the starter relay.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
Re: 74 duster no crank [Re: bdusted440] #1484275
08/16/13 01:03 AM
08/16/13 01:03 AM
IL,USA
IL,USA
found it.the box on the pass side firewall is bad.got ahold of mopar city and got the right wiring diagram.got a replacement from them.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
Re: 74 duster no crank [Re: bdusted440] #1484276
08/16/13 07:48 PM
08/16/13 07:48 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Do yourself a favor and bypass that PITA. All you need do is pull the two larger yellow/ yellow tracer wires out of the reset box and wire them permanently together.
Re: 74 duster no crank [Re: Yancy Derringer] #1484277
08/16/13 11:59 PM
08/16/13 11:59 PM
IL,USA
IL,USA
I did make a jumper and bypassed the seat belt relay. The box I replaced was for neutral safety and reverse lights.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
