Magnum 500 wheels question #1482771
08/11/13 01:07 PM
08/11/13 01:07 PM
West Palm Beach, Florida
Copper Dart Offline OP
I purchased a set of "Ford" Magnum 500 wheels to install on my '67 Satellite and they don't fit the hub. Correct bolt pattern but the axle hubs are too large diameter to fit the rims.
What do I do?
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482772
08/11/13 02:11 PM
08/11/13 02:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't recall ever having that problem; what I noticed was that clip-on weights on the inside of Ford 14x7s would hit the edge of the '68-'70 Mopar upper control arm. Those were drum brake cars.
You could try a 1/4" spacer ring; any thicker than that and there's not much thread engagement on stock studs.
If you use spacers and their holes are too big to be captured by the studs (meaning they move around on the drum), a few dabs of weatherstrip adhesive will hold them in place.
Should be a good market for 15x8s, as they fit the '68-later Bs fine.
Re: Magnum 500 wheels question [Re: topside] #1482773
08/11/13 02:18 PM
08/11/13 02:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Some Ford rims have a smaller register.You can open the hole up so they fit.Thats the easiest and safest way.Im not a fan of spacers.Rocky
Chrysler Firepower
Re: Magnum 500 wheels question [Re: topside] #1482774
08/11/13 02:24 PM
08/11/13 02:24 PM
Someone out there should know if the hub sizes changed or something. It's doesn't seem to be a huge difference but I don't want to screw anything up getting the dremel <sp> out .
I might just mark were the hub hits and try relieving both the rim and hub a little.
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482775
08/11/13 02:37 PM
08/11/13 02:37 PM
Topside, thanks for responding.
I won't use spacers but thanks for the input.
If this turns into a nightmare, I'll sell the rims off and save my penny's for some alloy wheels instead.
Too many early B-Body's with Magnum 500's anyway!
I would be happy with a style similar to the Torque Thrusts.
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: topside] #1482776
08/11/13 02:46 PM
08/11/13 02:46 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
fords should work...are you sure they are ford ?
Re: Magnum 500 wheels question [Re: terzmo] #1482777
08/11/13 02:57 PM
08/11/13 02:57 PM
I was told from a 1972 Mach I
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482778
08/11/13 03:36 PM
08/11/13 03:36 PM
I feel like I'm loosing my mind! This issue bothered me so much that I re-reviewed what the hell was going on and found 2 rims fit perfectly and 2 don't. The first one I grabbed didn't fit so I expected all 4 to be the same trouble. It seems that there is some fitment issues, I don't know if forcing them on would be a good idea, they can't be too far off. I will take pictures of both up close. Maybe relieving the rim would be a better idea than both the hubs and rims.
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482779
08/11/13 04:12 PM
08/11/13 04:12 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Magnum 500 don't truly register on the center hub anyways. Neither will most aftermarket rims.
Magnum 500 center on the lug tapers. And old magnum 500's will wear out the lug tapers and mushroom them out. Sometimes will cause a lug nuts to keep loosening up since they almost or are bottoming out on the flange behind the rim.
Are you having an issue with the front rims or rear?
I'd guess the stamping for the center is tight on the bearing snout in the front rims.
Re: Magnum 500 wheels question [Re: autoxcuda] #1482780
08/11/13 10:58 PM
08/11/13 10:58 PM
some pictures. look where the hub contacts the inside of the rim. I cant even force them to start to go on. hard to believe but even the stamp numbers inside the rims are the same. WTF?
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482781
08/11/13 10:59 PM
08/11/13 10:59 PM
nudder
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482782
08/11/13 11:00 PM
08/11/13 11:00 PM
now one that fits.
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482783
08/11/13 11:02 PM
08/11/13 11:02 PM
test hub.
yes I checked all of the hubs for fit not just this one.
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482784
08/12/13 12:31 AM
08/12/13 12:31 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Will the 1 taht are tight on the front fit the rear??? Its a common known fact that the Mopars have a larger hub than the Fords...
I am truckless..
Re: Magnum 500 wheels question [Re: 340SHORTY] #1482785
08/12/13 10:43 AM
08/12/13 10:43 AM
i put the '67 Satellite up on the rack and pulled one front and one rear to test fit the "Ford" Magnum 500 15x8's and two rims don't fit and two do. It seems that the inside of the rims that don't fit were not pressed correctly and the concave area that rides on the axle or hub is too tight.(see previous pictures) I will relieve them to fit without modifying the axle nor the hubs. I don't think it will be too much grinding.
Mom.
Ricky Valdes
Re: Magnum 500 wheels question [Re: Copper Dart] #1482786
08/13/13 11:15 AM
08/13/13 11:15 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Wow !!! I bought set of (5) 15x7 Road Wheels from Specialty Wheel, for my 1970 Sport Satellite. They fit perfect, and have the outside powder coated black, so I use the trim ring - just the way the original 14x6 road wheels were on the car.
Re: Magnum 500 wheels question [Re: a12rag] #1482787
08/13/13 09:39 PM
08/13/13 09:39 PM
Tehachapi CA
MRBELV2 Offline
MRBELV2  Offline
Tehachapi CA
I put the 14 x 7 ford magnums on my 69RR. They had small built up areas (almost like a spot weld) which register on the hubs. I lightly ground these off and they now fit. I have drum brakes and they needed a spacer to work on front.
