timing chain ??? (simple for some) #1482667
08/11/13 04:22 AM
08/11/13 04:22 AM
Mt Evelyn , Vic Australia
dartcharger Offline OP
Virgin Fluff
Virgin Fluff
Just trying to get some work done on the dart, im pritty sure i used the outer 0 on the crank cog last time i put a small block together on the timing chain. 25 year's later id like to be sure that's correct before i seal it off, anybody got a pic of how it should look or can you tell me inner or outer 0 on the timing chain crank cog. thanks
Re: timing chain ??? (simple for some) [Re: dartcharger] #1482668
08/11/13 08:58 AM
08/11/13 08:58 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Put the crankshaft in position so the woodruff key is at 1:30 clock position (when viewing from front of eng), and the "dot" should be straight up. That would be the outer dot, as you must have an advance-retard timing set.
Re: timing chain ??? (simple for some) [Re: dartcharger] #1482669
08/11/13 10:21 AM
08/11/13 10:21 AM
To go straight up use the keyway with the inner zero on it & that sets the tooth position of the outer zero (the dot). I would suggest degreeing it with all the crappy tolerances in parts these days & if advancing/retarding iirc the square is advanced & the triangle is retarded but not sure if they are all 4 deg or if some sets are 2 deg. As you know adv/ret will change VP clearance. OT someone asked about this the other day on a jumped timing chain thread, on a SB 1 whole tooth off is gonna change phasing 15.6 deg
Re: timing chain ??? (simple for some) [Re: RapidRobert] #1482670
08/11/13 08:38 PM
08/11/13 08:38 PM
scratchnfotraction Offline
in hughesengine instruction sheet for cam swap
you line up the crank at 12 oclock with cam gear at 6 oclock, dot to dot.
then rotate crank one full turn to get the cam gear dot at 12 oclock and the crank gear at 12 oclock.
THEN drop the dist in with the rotor at #1 cap term setting it just a little before the rotor is lined up with cap term AND damper set at 10* BTDC.
this will give a instant start up and will not be 180* out.
Re: timing chain ??? (simple for some) [Re: scratchnfotraction] #1482671
08/11/13 09:27 PM
08/11/13 09:27 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
from the factory service manual
Re: timing chain ??? (simple for some) [Re: twodoorpost] #1482672
08/11/13 09:50 PM
08/11/13 09:50 PM
thats what it calls for per the manual.
BUT when you drop the dist in with rotor pointing at #1 term on cap,it will be 180* out of time.
I have done it that way for 30 yrs and always have been 180* out and have to reset dist on my engine every time.
now here in 2013 I swap in a hughes cam and read the instructions to turn it 1 full turn on the crank to get both dots 12 oclock high and set the dist to #1 term on cap with damper 10* BTDC.
it turned 1/2 turn of crank and fired right up and idled.
I just put another one in this week and just set the dots at 12 oclock high and set damper/dist 10*/#1 term on cap.
set curb idle to 2300 rpm fired it off and 1/2 turn on crank it fires and comes up to 2300 rpm for the 20 min break in on cam.
just sayin
Re: timing chain ??? (simple for some) [Re: twodoorpost] #1482673
08/11/13 10:15 PM
08/11/13 10:15 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Did anybody proof read those FSMs back then? Both sprockets labeled camshaft...
Re: timing chain ??? (simple for some) [Re: vdriver] #1482674
08/16/13 10:09 AM
08/16/13 10:09 AM
Virgin Fluff
Virgin Fluff
thanks guy's, its so much easyer with some simple instructions to follow. iv got a factory manuel sitting next to the motor but only use it for torque settings, no good for after market timing chains.
Re: timing chain ??? (simple for some) [Re: dartcharger] #1482675
08/16/13 01:53 PM
08/16/13 01:53 PM
I've had after market timing sets that have to be degreed to have the cam installed correctly, on those you can not get the dots lined up perfectly. The cam dot will not align perfectly with the crank dot, the dot will be off a tiny bit either way, not perfect One tooth on the cam gear is right at 12 degrees retarded or advanced Degree it
Re: timing chain ??? (simple for some) [Re: Cab_Burge] #1482676
08/17/13 12:49 AM
08/17/13 12:49 AM
Virgin Fluff
Virgin Fluff
i will degree it, maybe tonight if it's warm enough to play in the barn. iv never degreed a cam before but have allway's wanted to learn, so this will be the motor to learn on.
Re: timing chain ??? (simple for some) [Re: dartcharger] #1482677
08/17/13 01:30 AM
08/17/13 01:30 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: timing chain ??? (simple for some) [Re: OzHemi] #1482678
08/17/13 01:41 AM
08/17/13 01:41 AM
Virgin Fluff
Virgin Fluff
something constructive would be nice to hear Jeff
Re: timing chain ??? (simple for some) [Re: dartcharger] #1482679
08/17/13 01:44 AM
08/17/13 01:44 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I sent a shovelhead over there and about to advertise it....if you are in the market.
Is that constructive?
Aside from that....I have a cam degree wheel if you need to borrow one.
Re: timing chain ??? (simple for some) [Re: OzHemi] #1482680
08/17/13 04:18 AM
08/17/13 04:18 AM
Virgin Fluff
Virgin Fluff
Thank's, i have a degree wheel and i hope to be in the market for the last of the kicker's soon (85 wide glide)but not quiet ready yet. send me a pm with the price you want for it. and yes thats better
Re: timing chain ??? (simple for some) [Re: dartcharger] #1482681
08/17/13 09:50 AM
08/17/13 09:50 AM
If you ain't already I'd checkout Frankendusters' nearby cam degree thread
Re: timing chain ??? (simple for some) [Re: dartcharger] #1482682
08/17/13 11:54 AM
08/17/13 11:54 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Mine is the last of them pretty much....'84 Shovel (kick start with a belt drive)
Has a reco'd trans and motor was done with an S&S top end..
PM me with an offer.
And cool deal you already have the degree wheel.
