Concerned over header clearance, burning paint #1482333
08/10/13 02:10 PM
08/10/13 02:10 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
I am getting ready to fire the Dart. It has 2" TTIs on it, and the clearance to the pass side fender well is really close. The headers are ceramic coated and the car is painted base/clear.
I know these headers are *really* overkill for what I have now. But the plan is to upgrade the engine, so I didn't want to have to buy a bunch of stuff twice. The only reason I am running them.
Anyone have any similar experience? Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: Concerned over header clearance, burning paint [Re: Crazy68Dart] #1482334
08/10/13 03:22 PM
08/10/13 03:22 PM
How close?
Re: Concerned over header clearance, burning paint [Re: RapidRobert] #1482335
08/10/13 06:01 PM
08/10/13 06:01 PM
Canton, Ohio
Canton, Ohio
The obvious question.
Re: Concerned over header clearance, burning paint [Re: Crazy68Dart] #1482336
08/10/13 06:02 PM
08/10/13 06:02 PM
Canton, Ohio
Canton, Ohio
nutha
Re: Concerned over header clearance, burning paint [Re: Crazy68Dart] #1482337
08/10/13 06:02 PM
08/10/13 06:02 PM
Canton, Ohio
Canton, Ohio
stance check.
Re: Concerned over header clearance, burning paint [Re: Crazy68Dart] #1482338
08/10/13 06:53 PM
08/10/13 06:53 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
That looks like plenty of distance. The paint is remarkably tough people have been known to paint engines with it and it works fine. Yes it'll get hot, but not enough to burn. Now if that cylinder goes way lean and turns that tube red hot all bets are off. Also make sure you timing is never retarded a bunch that'll make the tubes glow too.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Concerned over header clearance, burning paint [Re: HemiRick] #1482339
08/10/13 07:12 PM
08/10/13 07:12 PM
Canton, Ohio
Canton, Ohio
I was thinking it would be okay, but wanted to ask. Even if it would discolor a little with the color it probably would not be noticeable. I ran the engine already, so I know where the timing is, etc. The carb has the stock jets DP 750 which I think are 80 in the front and 82 in the back? Been a while since I had it apart.
Re: Concerned over header clearance, burning paint [Re: HemiRick] #1482340
08/11/13 10:44 AM
08/11/13 10:44 AM
You're good on the pass side
Re: Concerned over header clearance, burning paint [Re: RapidRobert] #1482341
08/11/13 11:45 AM
08/11/13 11:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You should be fine. I know you cant see it to good but my pass header is about that close and it has not burnt the fenderwell paint at all. Ron
