Re: Where can I get rubber sheeting for.........
[Re: bigblock340power]
#1482315
08/10/13 03:02 PM
08/10/13 03:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
#1482318
08/10/13 10:18 PM
08/10/13 10:18 PM
Posts: 5,365 Rancho Cordova, California (Sa...
hemi71x
Hey, Mike'y. I used to drive by Capital Rubber on 19th Street, every day on my way home, when i was working full time, in mid town Sacramento. Dunno, give them a try.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Diplomat440]
#1482320
08/11/13 03:19 AM
08/11/13 03:19 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I don't know how fuel resistant the rubber is, but in the printing world (offset printing) the press operators use a "press blanket" to cover the press rollers and absorb the pounding from production. After a certain number of impressions are run, they are replaced and not re-used. I have several blankets from the printing company that I worked at, but I have not figured out what I am going to do with them yet. If I knew how big a piece you needed, I could cut one up and mail it to you.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
#1482321
08/11/13 07:15 AM
08/11/13 07:15 AM
Posts: 1,978 USA
Suregrip391
USA
gas caps. To make my own rubber sealing rings. I can find rubber sheeting all day long W/fiber reinforcement. Do not want fiber threads in the rubber sheeting! Not sure of the thickness, but you all know what I'm talking about. Thanks
Find an industrial type supply house for plumbing materials. They sell rubber in sheets / rolls as gasket material between large pipe flanges. Might be able to get what you need there.
[Re: Polarapete]
#1482322
08/11/13 09:06 AM
08/11/13 09:06 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Wow! Thank you. A hunk that would fit in a standard "Office size" envelope (4 1/8 X 9 1/2) would do very nicely. I'm thinking a single stamp would get to me OK. I can PM my address if OK with you (wish I could send you some bucks somehow for your trouble).
