Where can I get rubber sheeting for......... #1482311
08/10/13 12:06 PM
08/10/13 12:06 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
gas caps. To make my own rubber sealing rings. I can find rubber sheeting all day long W/fiber reinforcement. Do not want fiber threads in the rubber sheeting! Not sure of the thickness, but you all know what I'm talking about.
Re: Where can I get rubber sheeting for......... [Re: bigblock340power] #1482312
08/10/13 12:39 PM
08/10/13 12:39 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Contact a plastics company in your area, I believe you have TAP Plastics in your area (if they are still in business). Otherwise look up rubber suppliers in the Thomas Guides (online or at your library). Also, industrial supply companies often sell rubber matts for non slip flooring surfaces and counter tops, check with them to get proper thickness.
Re: Where can I get rubber sheeting for......... [Re: ScottSmith_Harms] #1482313
08/10/13 12:46 PM
08/10/13 12:46 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Out of curiosity....Would "generic" type rubber be resistant to the gasoline out there now a days?
And there is always Amazon too..
http://www.amazon.com/s/ref=nb_sb_noss_2...rnid=2941120011
Re: Where can I get rubber sheeting for......... [Re: OzHemi] #1482314
08/10/13 01:05 PM
08/10/13 01:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Todays fuels are hard on any rubber. Neoprene would be better suited when speaking on todays fuel, but a rubber gas cap seal doesn't get much fuel exposure so I don't think it's a huge issue, not to mention it's correct.
Re: Where can I get rubber sheeting for......... [Re: bigblock340power] #1482315
08/10/13 03:02 PM
08/10/13 03:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Where can I get rubber sheeting for......... [Re: bigblock340power] #1482316
08/10/13 06:34 PM
08/10/13 06:34 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
If small quanties and price is not a major concern, Grainger has a decent selection of rubber that may solve your problem.
Re: Where can I get rubber sheeting for......... [Re: jcc] #1482317
08/10/13 08:20 PM
08/10/13 08:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Might try restorationspecialties.com too. I've bought replacement gas caps from the local auto parts store and swapped the rubber ring to an original cap. More expensive solution, but already cut to shape.
Re: Where can I get rubber sheeting for......... [Re: bigblock340power] #1482318
08/10/13 10:18 PM
08/10/13 10:18 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Hey, Mike'y.
I used to drive by Capital Rubber on 19th Street,
every day on my way home, when i was working full time, in mid town Sacramento.
Dunno, give them a try.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Where can I get rubber sheeting for......... [Re: bigblock340power] #1482319
08/10/13 10:43 PM
08/10/13 10:43 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
old truck inner tube or better yet the flap,they seem a little thicker.
Re: Where can I get rubber sheeting for......... [Re: Diplomat440] #1482320
08/11/13 03:19 AM
08/11/13 03:19 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I don't know how fuel resistant the rubber is, but in the printing world (offset printing) the press operators use a "press blanket" to cover the press rollers and absorb the pounding from production. After a certain number of impressions are run, they are replaced and not re-used. I have several blankets from the printing company that I worked at, but I have not figured out what I am going to do with them yet. If I knew how big a piece you needed, I could cut one up and mail it to you.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Where can I get rubber sheeting for......... [Re: bigblock340power] #1482321
08/11/13 07:15 AM
08/11/13 07:15 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Find an industrial type supply house for plumbing materials. They sell rubber in sheets / rolls as gasket material between large pipe flanges. Might be able to get what you need there.
Re: Where can I get rubber sheeting for......... [Re: Polarapete] #1482322
08/11/13 09:06 AM
08/11/13 09:06 AM
Elk Grove, Calif.
Elk Grove, Calif.
Wow! Thank you.
A hunk that would fit in a standard "Office size" envelope (4 1/8 X 9 1/2) would do very nicely. I'm thinking a single stamp would get to me OK. I can PM my address if OK with you (wish I could send you some bucks somehow for your trouble).
