1989 Dodge D-150 , wheel center bore size ?
#1482167
08/09/13 06:52 PM
08/09/13 06:52 PM
Posts: 34,905 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
If I was to purchase a set of 15 x 7's ?
5 on 5 1/2 bolt pattern wheels , etc
How large must the center of the wheel be to fit ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1989 Dodge D-150 , wheel center bore size ?
[Re: 340SHORTY]
#1482172
08/10/13 12:53 AM
08/10/13 12:53 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Large enough to fit over the hub register??
Like that answers the question ?
Not going to order without knowing
Truck is in my storage building and can't get it out without a hassle
[Re: bigdad]
#1482176
08/10/13 02:48 AM
08/10/13 02:48 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
MOST aftermarket wheels with 5 on 5.5 lug pattern have the large center hole for the earlier 4x4s.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: MoPar Jamie]
#1482180
08/10/13 05:17 AM
08/10/13 05:17 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Im going to have to side with Jamie on this one.
Most, not all, of the aftermarket wheels are sized with a center hole in the 4.25 to 4.28 diameter. They size them to fit the largest diameter hub and since they are lug centric, it doesn't matter to most people.
You can find some with a smaller hub, but many of those are a specialty wheel. Like Wheel Vintiques, or Cragar S/S type of wheels, etc.
[Re: bigdad]
#1482181
08/10/13 12:24 PM
08/10/13 12:24 PM
Posts: 1,357 central Florida
VL21
central Florida
As usual, I'm late to the party ... I measured a new rotor I have and it looks like 3.526 inches od on the hub register, and the spare wheel in the back of the truck seems to confirm that, though I cant get my gizmo down into the wheel ... subject to correction by the gods.
It takes gasoline to interest me.
