1989 Dodge D-150 , wheel center bore size ? #1482167
08/09/13 06:52 PM
08/09/13 06:52 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
If I was to purchase a set of 15 x 7's ?
5 on 5 1/2 bolt pattern wheels , etc
How large must the center of the wheel be to fit ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: bigdad] #1482168
08/09/13 07:48 PM
08/09/13 07:48 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Large enough to fit over the hub register??
I am truckless..
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: 340SHORTY] #1482169
08/09/13 08:04 PM
08/09/13 08:04 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: hp383] #1482170
08/09/13 08:05 PM
08/09/13 08:05 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
If your buying aftermarket wheels they will be plenty big enough. If you are buying an older Ford wheel then the hole will be too small.
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: hp383] #1482171
08/10/13 12:46 AM
08/10/13 12:46 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
We just put a set of 96 16" pick up rims on an 86 full size and if I remember right it was right around 4.325" center we had it opened up to. We measured and it was tight enough that we used a die grinder to open it up even more. We rough measured with a tape measure and added an eighth inch. I may be off with the measurement, but for some reason that number sticks in my mind.
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: 340SHORTY] #1482172
08/10/13 12:53 AM
08/10/13 12:53 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Like that answers the question ?
Not going to order without knowing
Truck is in my storage building and can't get it out without a hassle
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: bigdad] #1482173
08/10/13 01:23 AM
08/10/13 01:23 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I'll measure with pics tomorrow. Can't you check the chrome slots you have?
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: 76dodgeboy] #1482174
08/10/13 02:19 AM
08/10/13 02:19 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I can sure do that
but , that does not ,mean that I can't get by with less ..
I would like to buy a set without a gigantic center cap
Never mind .. wow
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: 76dodgeboy] #1482175
08/10/13 02:48 AM
08/10/13 02:48 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Arent your chrome Slots FACTORY meaning thats the size of the hole. It was a Simple suggestion. Like I said tomorrow I will with a Pic
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: bigdad] #1482176
08/10/13 02:48 AM
08/10/13 02:48 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
MOST aftermarket wheels with 5 on 5.5 lug pattern have the large center hole for the earlier 4x4s.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: MoPar Jamie] #1482177
08/10/13 03:47 AM
08/10/13 03:47 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Don't worry about it...
I'll pull a wheel and measure myself
I just thought you guys would know
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: MoPar Jamie] #1482178
08/10/13 03:49 AM
08/10/13 03:49 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
WRONG !!!!
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: bigdad] #1482179
08/10/13 05:04 AM
08/10/13 05:04 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
We dont really care about them having the smallest hub hole possible. Go ahead and measure yourself. I dont have to dig a truck out or pull a wheel but if you really feel the need
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: MoPar Jamie] #1482180
08/10/13 05:17 AM
08/10/13 05:17 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Im going to have to side with Jamie on this one.
Most, not all, of the aftermarket wheels are sized with a center hole in the 4.25 to 4.28 diameter. They size them to fit the largest diameter hub and since they are lug centric, it doesn't matter to most people.
You can find some with a smaller hub, but many of those are a specialty wheel. Like Wheel Vintiques, or Cragar S/S type of wheels, etc.
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: bigdad] #1482181
08/10/13 12:24 PM
08/10/13 12:24 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
As usual, I'm late to the party ...
I measured a new rotor I have and it looks like 3.526 inches od on the hub register, and the spare wheel in the back of the truck seems to confirm that, though I cant get my gizmo down into the wheel ...
subject to correction by the gods.
It takes gasoline to interest me.
Re: 1989 Dodge D-150 , wheel center bore size ? [Re: VL21] #1482182
08/12/13 06:07 PM
08/12/13 06:07 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Same size as the year before and the year after
