68 Coronet RT driveshaft lenth #1482155
08/09/13 04:47 PM
08/09/13 04:47 PM
So.IL.Home of Popeye
P
plum340demon Offline OP
P
I'm working on a buddy's 68 coronet rt 440 4 speed dana.The driveshaft that's in it is so long that it is pushing in on the tailshaft seal dust boot a little.I didn't think the yoke should be pushing in on the boot at all.Also this driveshaft has a big round wieght on the front just behind the yoke.I'v had several 69 and 70 b body's and never seen a driveshaft like this.Any help would be appreciated.
Re: 68 Coronet RT driveshaft lenth [Re: plum340demon] #1482156
08/09/13 05:04 PM
08/09/13 05:04 PM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
Which diff and transmission? I have seen the weighted ones like you are talking about, have one here... can't remember what it is from.
Re: 68 Coronet RT driveshaft lenth [Re: krisiesmopes] #1482157
08/09/13 05:10 PM
08/09/13 05:10 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
With the driveshaft disconnected from the rearend push it as far as it will go into the trans. There should be between 1/2 and 1" space between the Ujoint caps and the the place they seat in the rearend yoke. That is measured with the weight of the car on the springs. Either on the ground or on jack stands. The round weight was to reduce vibration.
Re: 68 Coronet RT driveshaft lenth [Re: krisiesmopes] #1482158
08/09/13 05:12 PM
08/09/13 05:12 PM
P
P
A833 4 speed and Dana 60
Re: 68 Coronet RT driveshaft lenth [Re: stumpy] #1482159
08/09/13 05:19 PM
08/09/13 05:19 PM
P
P
That is about what i have but the yoke rubbing on the boot concerned me.
Re: 68 Coronet RT driveshaft lenth [Re: plum340demon] #1482160
08/09/13 05:21 PM
08/09/13 05:21 PM
Grand Prairie,Texas
Grand Prairie,Texas
You could replace the seal with one that has no boot if it bugs you.
Re: 68 Coronet RT driveshaft lenth [Re: stumpy] #1482161
08/09/13 09:02 PM
08/09/13 09:02 PM
Alberta, Canada
K
K
Alberta, Canada
50.39"
Re: 68 Coronet RT driveshaft lenth [Re: plum340demon] #1482162
08/09/13 09:51 PM
08/09/13 09:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Maybe it came out of a car with 8 3/4?
