Vinyl roofs on superbirds.. why ? #1482119
08/09/13 03:11 PM
08/09/13 03:11 PM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
Why were vinyl roofs required on the Superbirds??
Re: Vinyl roofs on superbirds.. why ? [Re: RTshaker] #1482120
08/09/13 03:32 PM
08/09/13 03:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
After Chrysler found out what it cost to modify & refinish the roofs on '69 500s & Daytonas - they figured it was cheaper to put a vinyl top on the Superbirds.
Re: Vinyl roofs on superbirds.. why ? [Re: 6bblgt] #1482121
08/09/13 04:10 PM
08/09/13 04:10 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I'd agree with that...
To lessen the amount of roof body work required is the popular notion...
Re: Vinyl roofs on superbirds.. why ? [Re: RTshaker] #1482122
08/09/13 06:03 PM
08/09/13 06:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
To induce aerodynamic drag, to keep them just a tad under 200 MPH... JK
Re: Vinyl roofs on superbirds.. why ? [Re: RTshaker] #1482123
08/09/13 07:04 PM
08/09/13 07:04 PM
CT
mastiffd Offline
mastiffd  Offline
CT
I was under the impression the vinyl tops were put on because of a time crunch to ensure the race versions would be approved in time for 1970 Daytona 500.
Due to the rear window plug a lot of bodywork and paint was needed and would have taken far more time than slapping vinyl tops on.
Re: Vinyl roofs on superbirds.. why ? [Re: mastiffd] #1482124
08/09/13 08:01 PM
08/09/13 08:01 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The biggest "time crunch" the Superbird production faced was to get all the cars required, built before Jan 1 1970 to skirt the new Federal front bumper law that was about to take place...the vinyl top was just cost/time cutting measures as Chrysler had no intention of building street consumption/production units, NASCAR forced their hand with that, along with prodding from the "other" manufacturers, as well as Richard Petty jumping ship in 69 to FORD, as he had no "wing" to ride in 69
mike
Re: Vinyl roofs on superbirds.. why ? [Re: DAYCLONA] #1482125
08/09/13 09:04 PM
08/09/13 09:04 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
I read in a old mag another reason that all superbird had to be completed by jan 1 1970 was mandated end of vacuum headlights?
Re: Vinyl roofs on superbirds.. why ? [Re: 1970A13] #1482126
08/09/13 10:18 PM
08/09/13 10:18 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I would assume it was for the same reasons they did it on the RT/SE Challengers. MUCH cheaper than tooling up for a different roof to take the small window and less time consuming than finishing the plug so it would be invisible (cheaper).
Kevin
Re: Vinyl roofs on superbirds.. why ? [Re: RTshaker] #1482127
08/09/13 10:23 PM
08/09/13 10:23 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
OT did anybody see the recent Red Salt flats Daytona with the seriously revised nose, painted black to at least mimic the original look?
I would not have thought that would be a preferred shape for the Salt flats relative to the factory nose.
Re: Vinyl roofs on superbirds.. why ? [Re: RTshaker] #1482128
08/09/13 10:23 PM
08/09/13 10:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
CHEAPER
Coming soon!!!!
Re: Vinyl roofs on superbirds.. why ? [Re: 6bblgt] #1482129
08/09/13 10:26 PM
08/09/13 10:26 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
You pull that top off & you can really see what would be involved
I have pics of that area that I took when I looked at one to buy at "Mopars at the Battleship" ten years ago or so
I'll see if I can get them posted from floppy (I had a Mavica then)
Re: Vinyl roofs on superbirds.. why ? [Re: mastiffd] #1482130
08/09/13 11:46 PM
08/09/13 11:46 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Read or saw something about that on TV or in a book.
Re: Vinyl roofs on superbirds.. why ? [Re: MAVERICKSHEMI] #1482131
08/10/13 09:32 AM
08/10/13 09:32 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
So why were the chrome pieces on the A pillars? Guessing smooth for less drag, but not sure.
Re: Vinyl roofs on superbirds.. why ? [Re: 1970A13] #1482132
08/10/13 03:07 PM
08/10/13 03:07 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Don't think so, never heard that one....how would you explain 70-1 Ford Torinos with vacuum operated hidden headlites
Re: Vinyl roofs on superbirds.. why ? [Re: DAYCLONA] #1482133
08/10/13 06:08 PM
08/10/13 06:08 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
I was wondering about that,think i read it in a 69 car life mag,do 70 Corvettes have electric headlight openers?
Re: Vinyl roofs on superbirds.. why ? [Re: 1970A13] #1482134
08/10/13 08:58 PM
08/10/13 08:58 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i wouldn't put much weight into that theory. they are designed to open, in the event of a vacuum failure. the vacuum holds them shut. not having to do hours of bodywork to make it presentable is obvious. the a-pillar moldings are to reduce drag/turbulence across the windshield.
Re: Vinyl roofs on superbirds.. why ? [Re: 1970A13] #1482135
08/10/13 10:09 PM
08/10/13 10:09 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Corvettes got vac headlights in 68' & ended in 82'
Re: Vinyl roofs on superbirds.. why ? [Re: BulletBob] #1482136
08/12/13 12:07 AM
08/12/13 12:07 AM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
It was to make them faster. The little bumps break the grip the wind has on the roof causing minor turbulence. A smooth top causes drag at high speeds. From Mo-par itself. Same with a boat bottom.
Re: Vinyl roofs on superbirds.. why ? [Re: bdusted440] #1482137
08/12/13 01:17 AM
08/12/13 01:17 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
So that's why Petty couldn't break the 200 MPH barrier, they deleted the vinyl roof on his car,... "restrictor roof racing" ...Dam Bill France!
Re: Vinyl roofs on superbirds.. why ? [Re: DAYCLONA] #1482138
08/12/13 01:22 AM
08/12/13 01:22 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
LMAO...
