What will my junk run? (update with vid link)
#1481243
08/07/13 10:14 PM
08/07/13 10:14 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
Heading out to Muncie dragway friday night for some test& tune/grudge race action.I've been driving this thing on the street since 2010 and the LM2 and I have the tune pretty well sorted out.Any and all guesses are welcome. Car is a 67 Satellite,only light weight parts are the M-1 single plane intake and the Edelbrock heads.Has factory iron A/C(working),304 stainless turbo manifolds,5 gallon air/water intercooler tank in trunk,M.S.D. boost timing master, 20 gallon fuel cell,750 proform carb. Crane powermax cam 260-204 dur..427"lift IN. 272-216 dur. .454" lift ex. 112 lobe sep. 8.0:1 compression 383 .030" o.s.Stock 1966 bottom end.2 1/2" exhaust to rear axle. Ancient 11" fairbanks 2500ish stall convertor,Copes pro street valvebody,3.55 gears in an 8 3/4 rear. 315-60-15 tires and homemade(dimensionally copied)caltracs.Calvert 9 way adjustable rear shocks, very"tired" front shocks.I'm running 15 lbs. boost read in the intake plenum, and plan to fill the cooler tank with ice. My best guess on weight is about 3850-3900 with my 205 lbs. aboard.If they have the scales open at the track I'll get a real weight on it. This thing was built to be a cruiser, not a race car.
Re: What will my junk run?
[Re: Duner]
#1481249
08/08/13 10:25 AM
08/08/13 10:25 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I'm going to take a wild stab at it and say 11.70s @ 120 mph.
see I'd agree before reading Dzuters posts, he has a 360 w/ about the same tame build and he's deep into the 10's. He does have a better stall and trans brake... I'll say your 1st few runs will be in the mid-11's and get better as you figure out what it likes best
[Re: 67_Satellite]
#1481259
08/09/13 04:32 PM
08/09/13 04:32 PM
Guitar Jones
So ah, what was for lunch? Just want to eat vicariously through someone else, I haven't been able to eat lunch all week.
