PRIME THE PUMP IN WHAT DIRECTION? #1481235
08/07/13 09:46 PM
08/07/13 09:46 PM
Uranus
strokerchall Offline OP
Uranus
440,I believe it's the ooposite direction inwhich the vacuum advance points? So from the top looking down it's counter clockwise?
Re: PRIME THE PUMP IN WHAT DIRECTION? [Re: strokerchall] #1481236
08/07/13 09:51 PM
08/07/13 09:51 PM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
correct
Re: PRIME THE PUMP IN WHAT DIRECTION? [Re: Goat330] #1481237
08/07/13 09:56 PM
08/07/13 09:56 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yeppers, ccw for big block
Re: PRIME THE PUMP IN WHAT DIRECTION? [Re: strokerchall] #1481238
08/07/13 10:29 PM
08/07/13 10:29 PM
With the dampener slit on TDC (#6 cyl on compression) the pass head is lined up to be oiled. Back the crank up (CCW) 3/4 of a turn (rotor under #8 plug wire in dist cap) the drivers head is lined up to be oiled. EDIT if you do #8 then #6 (slit on TDC) then you can back the crank up slightly to 10 BTDC (mild cam) or 15 (wild cam) & set the dist in & turn the housing till the magnet is dead even with the tooth with the rotor under #6 plug wire & that area is ready to go
Re: PRIME THE PUMP IN WHAT DIRECTION? [Re: strokerchall] #1481239
08/08/13 10:32 AM
08/08/13 10:32 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
same way the rotor spins
Coming soon!!!!
