727 Trans leak. Is this a simple fix? #1480444
08/06/13 01:37 AM
08/06/13 01:37 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Leaking out the back. This looks like a plug, It had backed out and I was able to push it back in. Can I simply indent the case to stop the plug from moving forward?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: 727 Trans leak. Is this a simple fix? [Re: Kam*Kuda] #1480445
08/06/13 02:05 AM
08/06/13 02:05 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
That's the rear band lever shaft. It should have an o-ring on it, and the tab on the extension housing holds it from coming out. If it's leaking and coming out too far, you may be tearing a few things apart.
You could I suppose get lucky and make a little "bracket" to hold it in and mount it to the housing or pan bolts. But that won't solve the leak. I've found that even stuffing some RTV over the hole eventually starts seeping again.
By the way, the "tab" on the extension housing in your picture seems to be ground off.... shouldn't be....
Re: 727 Trans leak. Is this a simple fix? [Re: superwrench] #1480446
08/06/13 03:01 AM
08/06/13 03:01 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Isn't that what holds the shaft in?
Re: 727 Trans leak. Is this a simple fix? [Re: Lefty] #1480447
08/06/13 08:08 AM
08/06/13 08:08 AM
BDW Offline
BDW  Offline
Had same problem, here's a simple fix.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: 727 Trans leak. Is this a simple fix? [Re: BDW] #1480448
08/06/13 11:13 AM
08/06/13 11:13 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thanks Will give it a try
1654.5 Mustang
1955 Land Rover
Re: 727 Trans leak. Is this a simple fix? [Re: Kam*Kuda] #1480449
08/06/13 03:14 PM
08/06/13 03:14 PM
scratchnfotraction Offline
someone had a post about this a while back.
they cut the tab off the tail housing to slide the shaft out just enuff to change the o-ring on it, then pushed it back in and made a small bolt on tab to hold the pin all the way forward.
the idea was to change the o-ring with trans in the car with out R&R of the tailhousing/pan/VB/low/revs strut/lever.
seemed to work ok for them when done.
I have fixed a couple by jacking up rear,clean with brake clean, airdry, use mopar ATF/RTV black filling in the hole/end of shaft.
the mopar ATF/RTV holds up the best with anything with trans fluid.
Re: 727 Trans leak. Is this a simple fix? [Re: scratchnfotraction] #1480450
08/06/13 06:14 PM
08/06/13 06:14 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
I cut the tab off mine last summer, replaced the o-ring and made a new tab out of flat bar. Had to remove the pan to tap the rod out. Seems like there are a couple threads about this.
However, it worked great. Here's some pix of mine.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: 727 Trans leak. Is this a simple fix? [Re: closer9] #1480451
08/06/13 06:58 PM
08/06/13 06:58 PM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
There is also a two o-ring reverse pin available. It is an OEM piece and found in some 727's. Two o-rings are always better than one.
