Best altenator??? #148022
11/09/08 11:22 PM
11/09/08 11:22 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
My altenator took a this eavning after 40 years of service on my 68 cuda. What aplication should I tell the guys at the parts store to get the highest output altenator that will bolt in and need no wiring changes? I need something tommorow so no fancy mail order stuff, the car is my daily driver.
Re: Best altenator??? [Re: HotRodDave] #148023
11/09/08 11:32 PM
11/09/08 11:32 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
With those restrictions rebuild the stocker.
Re: Best altenator??? [Re: HotRodDave] #148024
11/10/08 12:33 PM
11/10/08 12:33 PM
Andrewh Online content
Andrewh  Online Content
how about min wiring changes?
If none, then just ask for the same one you have.
Max amps is like 45 I think for a round back.
If you don't mind adding a ground wire and buying a swing arm, and fabbing a couple of spacers, you can get 74 amps from a square back.
They sell a genaric GM swing arm for about 10 bucks at every autoparts store.
Replace your old swing arm with that and add a few spacers from the block so it lines up with the alt.
Put a ground wire on one of the fields and wire up the other field to your old field wire and you are done.
Ask for the 89 m-body alt for the non-cop car 318, like a fury or dippy.
Re: Best altenator??? [Re: HotRodDave] #148025
11/10/08 12:50 PM
11/10/08 12:50 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If your wiring is stock I recommend just rebuilding yours.The parts places should have rebuild kits.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Best altenator??? [Re: HotRodDave] #148026
11/10/08 12:57 PM
11/10/08 12:57 PM
ask for one from a 75 mopar which will get you a good(for the time) squareback one & ground one field. Get either 1 or 2 groove pulleys that you want or have a shop R&R the pulley from your old one. If you were close I'd give you one out of my parts stash, I'm tired of tripping over them.
Re: Best altenator??? [Re: RapidRobert] #148027
11/10/08 03:35 PM
11/10/08 03:35 PM
Kalispell Mt.
Kalispell Mt.
I just threw out a couple before I moved from tennessee
Re: Best altenator??? [Re: HotRodDave] #148028
11/10/08 04:04 PM
11/10/08 04:04 PM
that's why I quit throwing stuff away.
Re: Best altenator??? [Re: HotRodDave] #148029
11/10/08 04:08 PM
11/10/08 04:08 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Rock auto list a 78 amp alternator for 77 Chrysler New Yorker(BECK/ARNLEY Part # 1866002).You would have to ground one field but other than that it's a direct swap.I'm sure you can get one of these from your local parts store also.
Re: Best altenator??? [Re: Ply72rr] #148030
11/10/08 10:32 PM
11/10/08 10:32 PM
Kalispell Mt.
Kalispell Mt.
I just picked up an altenator from o'reiley listed as a 70? amp altenator with the square back for a 75 duster. Don't matter witch one I ground does it? The one they listed for my car was 40 something amps and not in stock.
Also I was wondering, since the main wire runs through the amp meter before going to the battery (is that right?)would it be a good up grade to run a wire straight from the back of the altenator straight to the pos. terminal on the battery? Are there any cheap easy upgrades like that?
Re: Best altenator??? [Re: HotRodDave] #148031
11/10/08 10:50 PM
11/10/08 10:50 PM
ground either field wire & yes running a wire from alt(batt) to batt positive is good but instead connect it to the starter relay as it's a better place to connect to.
Re: Best altenator??? [Re: RapidRobert] #148032
11/10/08 10:52 PM
11/10/08 10:52 PM
Kalispell Mt.
Kalispell Mt.
What gauge wire or does any gauge help take some of the load off? I asume my amp gauge will no longer work if I do that?
Re: Best altenator??? [Re: HotRodDave] #148033
11/10/08 11:22 PM
11/10/08 11:22 PM
8 gauge & not accurate now
