Re: Best altenator???
[Re: HotRodDave]
#148025
11/10/08 12:50 PM
11/10/08 12:50 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If your wiring is stock I recommend just rebuilding yours.The parts places should have rebuild kits.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HotRodDave]
#148028
11/10/08 04:04 PM
11/10/08 04:04 PM
RapidRobert
that's why I quit throwing stuff away.
[Re: Ply72rr]
#148030
11/10/08 10:32 PM
11/10/08 10:32 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I just picked up an altenator from o'reiley listed as a 70? amp altenator with the square back for a 75 duster. Don't matter witch one I ground does it? The one they listed for my car was 40 something amps and not in stock.
Also I was wondering, since the main wire runs through the amp meter before going to the battery (is that right?)would it be a good up grade to run a wire straight from the back of the altenator straight to the pos. terminal on the battery? Are there any cheap easy upgrades like that?
[Re: HotRodDave]
#148031
11/10/08 10:50 PM
11/10/08 10:50 PM
RapidRobert
ground either field wire & yes running a wire from alt(batt) to batt positive is good but instead connect it to the starter relay as it's a better place to connect to.
