another ladder bar question #1479205
08/03/13 10:56 PM
08/03/13 10:56 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
just wondering if I will see any gains in my 60ft times, currently I see 1.46's..the scoop on the car 71 demon big block 727 trans d60 rear with 4.56 gears and 14x32 tires the rear susp is the old style leaf link and going to ladder bars just hoping for improvements
Thanks everyone in advance
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: another ladder bar question [Re: 67mprfan] #1479206
08/03/13 10:59 PM
08/03/13 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should see some over that leaf link... it wont
be as much as going from just leafs
Re: another ladder bar question [Re: MR_P_BODY] #1479207
08/03/13 11:10 PM
08/03/13 11:10 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Thanks Mike
I was hoping for low 1.40's the best so far this year was a 1.44
Re: another ladder bar question [Re: 67mprfan] #1479208
08/03/13 11:30 PM
08/03/13 11:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Mike
I think it will do that if not a touch better once
its dialed in
Re: another ladder bar question [Re: MR_P_BODY] #1479209
08/04/13 12:28 AM
08/04/13 12:28 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My barracuda 60's at 1.40 with 4.56 gear, 11.5- 29.5 tire with the ladder bars. When I went from clamped stock springs to the ladder bar it only improved maybe .002 but it sure made the car [ me ] feel better. Te car had spring wrap up and porpussed . The whole car would come of the track when I pulled 2nd gear.
Re: another ladder bar question [Re: rowin4] #1479210
08/04/13 04:55 PM
08/04/13 04:55 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
I Guess as long as I see some improvements I will be happy I really was just trying to get rear square up in the car because 1 side stick further than the other
Re: another ladder bar question [Re: 67mprfan] #1479211
08/04/13 04:57 PM
08/04/13 04:57 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
the other side
Re: another ladder bar question [Re: 67mprfan] #1479212
08/04/13 05:04 PM
08/04/13 05:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want you could cut the spring mounts off and center
the axle... or cut the one side and shorten it.. but
you might need the axle cut also
Re: another ladder bar question [Re: MR_P_BODY] #1479213
08/04/13 05:15 PM
08/04/13 05:15 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
we were going to do that but when tearing everything down we discovered on the ds the axle was rubbing up against the wheel cylinder and put a nice groove in it( which I feel really blessed it didn't rub a hole in it while making a pass) so we are going to start from scratch and add ladder bars for a upgrade.
Re: another ladder bar question [Re: 67mprfan] #1479214
08/04/13 05:17 PM
08/04/13 05:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Gotta ya
Re: another ladder bar question [Re: 67mprfan] #1479215
08/04/13 07:06 PM
08/04/13 07:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
That is a good find To bad it happened Take your time on centering the rear end in the car, it is not uncommon on Mopars to have what you found, the rear end is not center in the chassis What type of rear suspension are you going to use now, leaf springs with sliders , coil overs or ? Also what device, if your going to coil overs, are you going to use the keep the housing centered in the car? My Duster had coil overs and a diagonal link, that worked real well on the street and track I use to race another Duster years ago that had ladder bars with leaf springs with a slider set up on it and it drove real well also at the track, it wasn't a street and strip car though.
Re: another ladder bar question [Re: Cab_Burge] #1479216
08/04/13 07:18 PM
08/04/13 07:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
are you having traction problems now? if it's hooking now you probably wont see a lot of gain.if it's spinning you may gain some.
Re: another ladder bar question [Re: Cab_Burge] #1479217
08/04/13 09:39 PM
08/04/13 09:39 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Cab right now it has a leaf link set-up now i'm going with ladder bars and coil overs ditching the leaf springs
Re: another ladder bar question [Re: Quicktree] #1479218
08/04/13 09:43 PM
08/04/13 09:43 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
60 ft now avg 1.46's with the best this year at 1.44 so hoping to get low 1.40's
Re: another ladder bar question (Update) [Re: 67mprfan] #1479219
10/22/13 02:56 PM
10/22/13 02:56 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Hello everyone just to give an update after I got my car back with the new ladder bar set-up with coil overs
I've tested the car a few times but not going into the long details but the good new is on sunday I hit a new best .
1st pass rt.1.15 60ft.1.390 YEA et.6.420
2nd pass rt..443 RED 60ft.1.405 et.6.422
3rd pass rt..329 RED 60ft.1.407 et.6.442
4th pass rt..416 RED 60ft.1.419 et 6.451 very bad burnout
still got bugs to work out but did see some improvements
Re: another ladder bar question (Update) [Re: 67mprfan] #1479220
10/22/13 02:57 PM
10/22/13 02:57 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
another look of new stance on the car
Re: another ladder bar question (Update) [Re: 67mprfan] #1479221
10/22/13 02:58 PM
10/22/13 02:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
headed in the right direction
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: another ladder bar question (Update) [Re: 67mprfan] #1479222
10/22/13 03:17 PM
10/22/13 03:17 PM
Which type coil overs, single or double adjsutable? I should have elaborated a little more about buying a double adjustable with 6 inches or longer total travel(3 inches up, 3 inches down), sorry I didn't
Re: another ladder bar question (Update) [Re: Cab_Burge] #1479223
10/22/13 03:37 PM
10/22/13 03:37 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Cab they are qa-1 single adjustable I've been only to a couple of tracks since getting the car back in sept which is pacemaker and national trails and just been trying different dial set-up have not move the bars yet they are set in the middle hole
Re: another ladder bar question (Update) [Re: 67mprfan] #1479224
10/22/13 03:52 PM
10/22/13 03:52 PM
I had mine set in the next to the bottom hole on the 1/4 max four hole front mount, I moved it to the bottom and ended up changing from Strange single adjustable coil overs to the same set up with Strange double adjustables and switched from a 175 lb spring to a 150 lb. spring. The car ended up doing 1.37 60 ft. on a set of 13x30x15 M/T ET Street bias ply tires Try moving them up and down , lower hole for the good tracts and the higher hole for the bad tracts Make sure and reset the pinion angle also each time with the changes, my car like from negative(down)3 to 5 degrees from the pinion gear to the driveshaft Whats your thoughts on how the car drives now compared to the old set up
