another ladder bar question
#1479205
08/03/13 10:56 PM
08/03/13 10:56 PM
Posts: 1,030 ohio
67mprfan
ohio
just wondering if I will see any gains in my 60ft times, currently I see 1.46's..the scoop on the car 71 demon big block 727 trans d60 rear with 4.56 gears and 14x32 tires the rear susp is the old style leaf link and going to ladder bars just hoping for improvements
Thanks everyone in advance
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: another ladder bar question
[Re: 67mprfan]
#1479208
08/03/13 11:30 PM
08/03/13 11:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You should see some over that leaf link... it wont be as much as going from just leafs
Thanks Mike
I was hoping for low 1.40's the best so far this year was a 1.44
I think it will do that if not a touch better once its dialed in ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 67mprfan]
#1479212
08/04/13 05:04 PM
08/04/13 05:04 PM
MR_P_BODY
If you want you could cut the spring mounts off and center the axle... or cut the one side and shorten it.. but you might need the axle cut also ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 67mprfan]
#1479214
08/04/13 05:17 PM
08/04/13 05:17 PM
MR_P_BODY
we were going to do that but when tearing everything down we discovered on the ds the axle was rubbing up against the wheel cylinder and put a nice groove in it( which I feel really blessed it didn't rub a hole in it while making a pass) so we are going to start from scratch and add ladder bars for a upgrade.
Gotta ya ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 67mprfan]
#1479215
08/04/13 07:06 PM
08/04/13 07:06 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
That is a good find To bad it happened Take your time on centering the rear end in the car, it is not uncommon on Mopars to have what you found, the rear end is not center in the chassis What type of rear suspension are you going to use now, leaf springs with sliders , coil overs or ? Also what device, if your going to coil overs, are you going to use the keep the housing centered in the car? My Duster had coil overs and a diagonal link, that worked real well on the street and track I use to race another Duster years ago that had ladder bars with leaf springs with a slider set up on it and it drove real well also at the track, it wasn't a street and strip car though.
Re: another ladder bar question (Update)
[Re: 67mprfan]
#1479219
10/22/13 02:56 PM
10/22/13 02:56 PM
Posts: 1,030 ohio
67mprfan
ohio
Hello everyone just to give an update after I got my car back with the new ladder bar set-up with coil overs I've tested the car a few times but not going into the long details but the good new is on sunday I hit a new best . 1st pass rt.1.15 60ft.1.390 YEA et.6.420 2nd pass rt..443 RED ![](/ubbthreads/images/graemlins/tsk.gif) 60ft.1.405 et.6.422 3rd pass rt..329 RED ![](/ubbthreads/images/graemlins/rant.gif) 60ft.1.407 et.6.442 4th pass rt..416 RED ![](/ubbthreads/images/graemlins/spank.gif) 60ft.1.419 et 6.451 very bad burnout still got bugs to work out but did see some improvements
[Re: 67mprfan]
#1479220
10/22/13 02:57 PM
10/22/13 02:57 PM
Posts: 1,030 ohio
67mprfan
ohio
another look of new stance on the car
