Should I change the oil? #147867
11/09/08 07:30 PM
11/09/08 07:30 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
i have a 1968 chrysler 300 with a 440 CI engine. I have only drove it 283 miles in the past year and getting it ready for winter storage.It was drove 3 times approx 75-100 each time.Should I change the oil/filter? Change the filter and replace qrt of oil? Do nothing?
Re: Should I change the oil? [Re: 05dakota] #147868
11/09/08 07:32 PM
11/09/08 07:32 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would.
Re: Should I change the oil? [Re: 05dakota] #147869
11/09/08 07:36 PM
11/09/08 07:36 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I would change it in spring before the new season.
Re: Should I change the oil? [Re: 05dakota] #147870
11/09/08 07:40 PM
11/09/08 07:40 PM
I am a firm believer in frequent oil/filter changes despite the advent of synthetics & the extended oil change intervals that came along with them. I would change it & run it for several minute to coat everything with fresh uncontaminated oil.
Re: Should I change the oil? [Re: moparpollack] #147871
11/09/08 07:41 PM
11/09/08 07:41 PM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
283 miles ? of hwy type driving ?? ... don't worry about it.
Re: Should I change the oil? [Re: BeEtLeJuIcE !] #147872
11/09/08 07:46 PM
11/09/08 07:46 PM
the house on the left.
cogen80 Offline
cogen80  Offline
with only 300 miles on it i don't see the point in doing it before storage. i would do it in the spring .
Re: Should I change the oil? [Re: cogen80] #147873
11/09/08 08:15 PM
11/09/08 08:15 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I start mine in the winter every month and let her
get good and warm. Every spring I change it. I would
think given condensation etc, the spring time change
is much more critical.
Re: Should I change the oil? [Re: 05dakota] #147874
11/09/08 09:02 PM
11/09/08 09:02 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
I wouldn't even change it for Spring. If you do, save what you drain for me.
Re: Should I change the oil? [Re: 68Bullit] #147875
11/09/08 09:20 PM
11/09/08 09:20 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
where my cars are stored winter starting ist possible.
Re: Should I change the oil? [Re: 05dakota] #147876
11/09/08 09:37 PM
11/09/08 09:37 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
If not too late, take it for a good long cruise. Get it to operating temp and keep it there for a while to cook off the moisture and then park it.
Re: Should I change the oil? [Re: RapidRobert] #147877
11/09/08 10:26 PM
11/09/08 10:26 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
My thoughts exactly.
