Page 2 of 3 1 2 3
Re: A very very nice stick car [Re: 68LAR] #1478669
10/31/13 09:35 PM
10/31/13 09:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
thanks for the info.
i gotta say....5400 launch.....thats pretty brave
Re: A very very nice stick car [Re: fast68plymouth] #1478670
10/31/13 11:29 PM
10/31/13 11:29 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I'm considering that CFDF clutch but I can't find an 11" 18-spline disc !!
Re: A very very nice stick car [Re: Stanton] #1478671
11/01/13 09:34 AM
11/01/13 09:34 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Part# DF071800 for the complete assembly
Part# DF384071 for the disc only
I just bought a new assembly and used these numbers. 'Was going to use the old cover and just buy the disc, but changed my mind.
Why?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A very very nice stick car [Re: 68LAR] #1478672
11/01/13 10:00 AM
11/01/13 10:00 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
What sort of power are you putting out? This is the problem buying clutches, they rate them as "street, "street/strip", etc but in reality this is meaningless.
My motor is a stroker in the 600 hp range, mainly street use in a '69 b-body. I currently have a Hays "street" pp with the hays "street/strip disc". Since the motor isn't in the car yet I'd rather sort this clutch issue out now.
Thanks.
Re: A very very nice stick car [Re: Stanton] #1478673
11/01/13 11:30 AM
11/01/13 11:30 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
As stated in my sig, I've gone 11.14 @ almost 123 mph. HP calculator with a 3900+# car says that I'm making around 635 hp at the flywheel and around 545 at the back tires. With the CFDF I've pull 1.50 60' times. Most of the time I'm around 1.58, spinning the tires a bit.
Thanks.
By the way, I've used this Hays set up that you have now. It doesn't work at our power levels.
Re: A very very nice stick car [Re: 68LAR] #1478674
11/01/13 01:48 PM
11/01/13 01:48 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Thanks for the info. One last question ... are the trowout bearings pretty much standard between the CFDF and my current Hays setup or would I have to replace that too (its brand new).
Re: A very very nice stick car [Re: Stanton] #1478675
11/01/13 03:09 PM
11/01/13 03:09 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
The short answer is "Yes". 'Slight differences in the face that touches the pressure plate,some are wider than others, but all in all they are the same.
Re: A very very nice stick car [Re: 68LAR] #1478676
11/01/13 05:43 PM
11/01/13 05:43 PM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
So, I take it you're slipping the tires a bit on the launch to soften the hit on the drive line? I'm glad to see the 18-spline is living at over 600 HP.
Awesome car, btw. Love stick cars.
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: A very very nice stick car [Re: 6pak2go] #1478677
11/01/13 06:34 PM
11/01/13 06:34 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Exactly. Something has to slip at launch, either the clutch or the tires. I prefer to spin the tires a bit. With an automatic, the converter does the slipping.
Re: A very very nice stick car [Re: 68LAR] #1478678
11/01/13 06:44 PM
11/01/13 06:44 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
personally, I like the slow left leg method to protect the drivetrain That happens as you get older (right?)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: A very very nice stick car [Re: oldiron] #1478679
11/01/13 09:11 PM
11/01/13 09:11 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
What are you trying to say??????
Re: A very very nice stick car [Re: 68LAR] #1478680
11/01/13 09:19 PM
11/01/13 09:19 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
nothing, not me
Re: A very very nice stick car [Re: oldiron] #1478681
11/01/13 09:23 PM
11/01/13 09:23 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Thought you were trying to say that I was slowing down because I'm older than you?
Re: A very very nice stick car [Re: Stanton] #1478682
11/01/13 09:58 PM
11/01/13 09:58 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Centerforce is no longer producing 18 spline discs so whatever you find is old stock.I got the "backorder" runaround when I was looking for a new CF DF disc so I ordered a new McLeod 600 series disc from Jamie Passon.
I'm gonna try the Centerforce II plate with the McLeod 600 series disc and see how that works out
Gus
64 Plymouth Savoy
Dana 60
Re: A very very nice stick car [Re: fourgearsavoy] #1478683
11/02/13 12:32 AM
11/02/13 12:32 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Shoulda tried Summit ... stocked item !!!
Re: A very very nice stick car [Re: Stanton] #1478684
11/02/13 11:25 AM
11/02/13 11:25 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
So does Jegs.
Re: A very very nice stick car [Re: 68LAR] #1478685
11/02/13 08:12 PM
11/02/13 08:12 PM
Rittman Ohio
Rittman Ohio
Called Jegs and went to the counter at Summit and NEITHER store had the 11" 18 spline dual friction disc in the stock. That is when I called Jamie and he didn't have any left and told me why.
So I ended up with the McLeod
Gus
64 Plymouth Savoy
Dana 60
Re: A very very nice stick car [Re: fourgearsavoy] #1478686
11/03/13 12:42 AM
11/03/13 12:42 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Don't know when you did that but last night on Summits site it showed the disc part would ship immediately, meaning in stock. Jegs showed a few days delay, meaning no stock.
I just order the pp and disc as a kit from Jegs, ships Monday.
When did you get that pp on clearance from Summit? Is that an "in store" deal only?
Re: A very very nice stick car [Re: Stanton] #1478687
11/03/13 12:13 PM
11/03/13 12:13 PM
Rittman Ohio
Rittman Ohio
The plate I got from Summit was on the clearance and return tables.In the store they put all kinds of stuff out there, some scratch and dent items and some wrongly ordered parts.
When I bought the plate I walked up to the counter to buy the matching disc and they were on backorder according to my sales "professional".
So I then asked about the DFX disc and they told me it would take 6-8 weeks for my order so I said no thanks and called Jamie for a comparable disc.
Gus
64 Plymouth Savoy
Dana 60
Re: A very very nice stick car [Re: fourgearsavoy] #1478688
11/03/13 12:27 PM
11/03/13 12:27 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
So I then asked about the DFX disc and they told me it would take 6-8 weeks for my order.....
The only reason I went with the Ram disc was because the DFX disc was on back order when I was ready for it. I changed my mind about the DFX disc due to cost if for no other reason.
This must have been earlier this year. Around April or May. That's about the time I was looking to buy a DFX disc.
Page 2 of 3 1 2 3
