Re: A very very nice stick car
[Re: 68LAR]
#1478669
10/31/13 09:35 PM
10/31/13 09:35 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
thanks for the info. i gotta say....5400 launch.....thats pretty brave
[Re: 68LAR]
#1478672
11/01/13 10:00 AM
11/01/13 10:00 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'm considering that CFDF clutch but I can't find an 11" 18-spline disc !!
Part# DF071800 for the complete assembly Part# DF384071 for the disc only I just bought a new assembly and used these numbers. 'Was going to use the old cover and just buy the disc, but changed my mind.
What sort of power are you putting out? This is the problem buying clutches, they rate them as "street, "street/strip", etc but in reality this is meaningless.
My motor is a stroker in the 600 hp range, mainly street use in a '69 b-body. I currently have a Hays "street" pp with the hays "street/strip disc". Since the motor isn't in the car yet I'd rather sort this clutch issue out now.
Thanks.
[Re: 68LAR]
#1478676
11/01/13 05:43 PM
11/01/13 05:43 PM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
So, I take it you're slipping the tires a bit on the launch to soften the hit on the drive line? I'm glad to see the 18-spline is living at over 600 HP. Awesome car, btw. Love stick cars.
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: 68LAR]
#1478678
11/01/13 06:44 PM
11/01/13 06:44 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
personally, I like the slow left leg method to protect the drivetrain That happens as you get older (right?)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: Stanton]
#1478682
11/01/13 09:58 PM
11/01/13 09:58 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Centerforce is no longer producing 18 spline discs so whatever you find is old stock.I got the "backorder" runaround when I was looking for a new CF DF disc so I ordered a new McLeod 600 series disc from Jamie Passon. I'm gonna try the Centerforce II plate with the McLeod 600 series disc and see how that works out Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 68LAR]
#1478685
11/02/13 08:12 PM
11/02/13 08:12 PM
fourgearsavoy
Rittman Ohio
Called Jegs and went to the counter at Summit and NEITHER store had the 11" 18 spline dual friction disc in the stock. That is when I called Jamie and he didn't have any left and told me why. So I ended up with the McLeod Gus
[Re: Stanton]
#1478687
11/03/13 12:13 PM
11/03/13 12:13 PM
fourgearsavoy
Rittman Ohio
The plate I got from Summit was on the clearance and return tables.In the store they put all kinds of stuff out there, some scratch and dent items and some wrongly ordered parts. When I bought the plate I walked up to the counter to buy the matching disc and they were on backorder according to my sales "professional". So I then asked about the DFX disc and they told me it would take 6-8 weeks for my order so I said no thanks and called Jamie for a comparable disc. Gus
