75 Power Wagon rear window install tips ?? #1478639
08/02/13 10:26 PM
08/02/13 10:26 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I thought it would be easier than this.
I pulled the foggy, crappy aftermarket rear slider out of the Power Wagon today. I have a one piece tinted back glass that I am trying to install.
I've installed windshields and curved rear windows in Dusters, but this flat glass is giving me cuss fits.
I tried checking on youtube but most of what I see is urethane type installs.
Is the rubber gasket different with the sliders versus the one piece glass?
Any suggestions?
Thanks, Greg
Re: 75 Power Wagon rear window install tips ?? [Re: Kern Dog] #1478640
08/02/13 11:11 PM
08/02/13 11:11 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Are you dealing with a nice new, soft rubber gasket, or an old hard one?
If you are reusing the one from the slider, might want to check 2 things, 1) some sliders are a little smaller the others, seems I remember Dodge used 2 different suppliers for the sliders, one was a little smaller then the other, the difference between the 2 sizes was made up in the gasket, if I remember correctly. The glass was the same size as the larger slider (maybe there were 2 different size rear windows ).
2) If the slider was aftermarket, the thickness of the rubber gasket flange may be thinner the the thickness of the glass.
At any rate, I do remember people having issues with glass/slider sizes being different in some cases. How is that for good news? Sorry. Gene
Re: 75 Power Wagon rear window install tips ?? [Re: Kern Dog] #1478641
08/02/13 11:43 PM
08/02/13 11:43 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I believe the gasket is different between the two but not sure. Its alot easier with 2 people. I've installed a few flat. Tried to do a slider but we could not get it. Neighbors kids busted out the one that was in it
Re: 75 Power Wagon rear window install tips ?? [Re: Kern Dog] #1478642
08/02/13 11:56 PM
08/02/13 11:56 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Put the glass in the rubber, put a small nylon rope in the outer groove crossing at the bottom. Two people, silicone the seal and rope place the glass into the cab opening bottom side first. Get the rope inside and have the guy on the outside hold the glass to the cab as you pull the rope pulling the seal to the inside around the pinch welded seam. 5 minute job.
Re: 75 Power Wagon rear window install tips ?? [Re: NITROUSN] #1478643
08/03/13 12:05 AM
08/03/13 12:05 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thank you, thank you...
I found out that the gasket used with the slider window was different and used a lock strip. The non slider window was bigger than the frame of the slider, so a different gasket was required.
I dug around my stash and found a gasket I saved from a truck I parted out in 2010. It uses no lock strip. I did as Nitrousn suggested, I put the gasket on the glass, then I put a 5/16 rope in the channel. I was able to install it myself in about 10 minutes after I got my head on straight.
Thanks again guys. I appreciate the tips.
Re: 75 Power Wagon rear window install tips ?? [Re: Kern Dog] #1478644
08/03/13 02:41 PM
08/03/13 02:41 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I did a slider with the chrome lock strip recently, after that experience I would recommend the rope gaskets to anyone.
Re: 75 Power Wagon rear window install tips ?? [Re: CTD5.9] #1478645
08/03/13 07:34 PM
08/03/13 07:34 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
