4-sp reverse light stays on #147857
11/09/08 06:58 PM
11/09/08 06:58 PM
Ashburn, Virginia
ashburnmike Offline OP
Ashburn, Virginia
My reverse light stays on all the time.
I did the wiring according to the manual.
Where have I gone wrong here?
thanks
mike
Re: 4-sp reverse light stays on [Re: ashburnmike] #147858
11/09/08 07:48 PM
11/09/08 07:48 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Automatic or manual? Maybe you reverse switch is bad
Re: 4-sp reverse light stays on [Re: Scott Carl] #147859
11/09/08 07:53 PM
11/09/08 07:53 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Maybe your reverse switch is bad
I was going to suggest the same.
Are your backup lights functioning correctly when you engage the trans into reverse?
Re: 4-sp reverse light stays on [Re: In_The_Pink] #147860
11/09/08 08:01 PM
11/09/08 08:01 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Good call. See if the reverse lights
outside the car come on. I just had mine apart
in the spring. Also, make sure the switch is good, and the correct one for your car. A guy
at NAPA sold me the wrong one which I had to
return for what they had listed as a wrong item.
Re: 4-sp reverse light stays on [Re: Dart 340] #147861
11/09/08 08:06 PM
11/09/08 08:06 PM
Ashburn, Virginia
Ashburn, Virginia
it's a 70 A Body 4 Speed. Back up lights stay off until I put it in reverse. Work just like they're supposed to. Could there some kind of ground I'm missing?
Re: 4-sp reverse light stays on [Re: ashburnmike] #147862
11/09/08 08:12 PM
11/09/08 08:12 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
Maybe a short somewhere? A few years ago the wire going to my trans. on my Road Runner managed to come out of the retaining clip and make contact with a hot exhaust pipe when I was on the freeway. The reverse light came on and it stayed on until I discovered the wire was shorted on the exhaust pipe.
Re: 4-sp reverse light stays on [Re: ashburnmike] #147863
11/09/08 08:12 PM
11/09/08 08:12 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I am guessing it's a similar circuit to my A body.
The dash mounted light has a single wire feeding it.
Thats the power in, the other part of the circuit is
made by the ground on the dash. I'd trace down that
single wire to make sure it goes where it's supposed to.
My car had some really bad amateur wiring done on it. Took a long time to fix. Dome lights came on
with brakes etc. It was a mess. Hang in there and
take it one wire at a time.
Re: 4-sp reverse light stays on [Re: ashburnmike] #147864
11/09/08 08:23 PM
11/09/08 08:23 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Light on dash must be wired wrong. Both lights are operated off the one switch on trans.
Re: 4-sp reverse light stays on [Re: buildanother] #147865
11/09/08 08:53 PM
11/09/08 08:53 PM
Ashburn, Virginia
Ashburn, Virginia
Thanks for the input. I'll pull it all apart, re-install everything and see if that does anything.
Re: 4-sp reverse light stays on [Re: buildanother] #147866
11/09/08 09:43 PM
11/09/08 09:43 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Double check the position of the white/black wire running from the light into the bulkhead connector, and make sure it's located in the proper cavity.
If the dash reverse light illuminates, you know it's grounding, so the problem is in the wire which feeds power to the light.
This setup was removed from a '76 Duster 4-speed car:
