Re: 4-sp reverse light stays on
[Re: Scott Carl]
#147859
11/09/08 07:53 PM
11/09/08 07:53 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Maybe your reverse switch is bad
I was going to suggest the same.
Are your backup lights functioning correctly when you engage the trans into reverse?
[Re: In_The_Pink]
#147860
11/09/08 08:01 PM
11/09/08 08:01 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Good call. See if the reverse lights outside the car come on. I just had mine apart in the spring. Also, make sure the switch is good, and the correct one for your car. A guy at NAPA sold me the wrong one which I had to return for what they had listed as a wrong item.
[Re: buildanother]
#147866
11/09/08 09:43 PM
11/09/08 09:43 PM
In_The_Pink
Milwaukee, WI
Light on dash must be wired wrong. Both lights are operated off the one switch on trans.
Double check the position of the white/black wire running from the light into the bulkhead connector, and make sure it's located in the proper cavity.
If the dash reverse light illuminates, you know it's grounding, so the problem is in the wire which feeds power to the light.
This setup was removed from a '76 Duster 4-speed car:
