'73 C-body disks; what master cylinder? #1478255
08/02/13 11:05 AM
08/02/13 11:05 AM
Central Ohio
BMChrysler68 Offline OP
Smarter than the average bear? I think not.
Central Ohio
I've got all the stuff for the '73 swap, but I'm not sure which MC to get. I'm wanting to run manual, but I don't see any options in terms of '73 manual MCs. Is my only option to use a power MC with a manual pushrod?
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: '73 C-body disks; what master cylinder? [Re: BMChrysler68] #1478256
08/02/13 12:21 PM
08/02/13 12:21 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Master cylinders aren't body specific. They all fit. Just find whatever application has manual discs and go from there. Look for one with a 15/16" bore if you can.
Also if you are going with manual brakes make sure you have a manual brake pedal set up. The pedal ratio is different power to manual.
Kevin
Re: '73 C-body disks; what master cylinder? [Re: Twostick] #1478257
08/02/13 01:26 PM
08/02/13 01:26 PM
Central Ohio
Central Ohio
Cool, thank you. I had a hunch they were all about the same, but I wasn't sure if the mounting differed from body to body. As for the pedal setup, part of the allure of a manual setup is that my car has manual drums already. Well, that and I don't want to have to worry about pulling enough vacuum.
360-4v, automatic
Re: '73 C-body disks; what master cylinder? [Re: BMChrysler68] #1478258
08/02/13 02:17 PM
08/02/13 02:17 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I have read a lot of guys like to go with a later 2 bolt aluminum master for a light 80's truck. There is an adapter plate for this swap.
I have mechanical Aptitude.
I can screw up anything.
Re: '73 C-body disks; what master cylinder? [Re: bboogieart] #1478259
08/02/13 02:49 PM
08/02/13 02:49 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Get a 69 or 70 C body master for disc drum.I run them on all my conversions.I assume you are installing the discs on a C body.My 65 B has one on now been on at least 12 years and my kids 62 300 has the same with power drum drum.Mine are manual disc.Rocky
Chrysler Firepower
Re: '73 C-body disks; what master cylinder? [Re: therocks] #1478260
08/02/13 03:49 PM
08/02/13 03:49 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Yep, I just used a 73 C body Manual Master when I converted the 65 Newport
Re: '73 C-body disks; what master cylinder? [Re: belv2vert66] #1478261
08/02/13 04:13 PM
08/02/13 04:13 PM
Central Ohio
Central Ohio
I can't find any '73 C-body disk MCs online that say they're for manual brakes. That's why I was asking. I think I'm going to buy an A-body one. They seem to be more available.
360-4v, automatic
