70 dash in 71 Cuda...is it possible from the factory? #1478199
08/02/13 09:41 AM
08/02/13 09:41 AM
italy
antonellomopar Offline OP
italy
I have a 71 Cuda project that is coming with a 70 style rallye dash. Car has 118.....vin, spd 904.
Could it be that some early cars were fitted with leftover parts from year before, or simply dash had been switched sometime in the past?
A friend of mine has a 71 Challenger conv 340 with the same thing, his car was also early producrion.
Thank you
Re: 70 dash in 71 Cuda...is it possible from the factory? [Re: antonellomopar] #1478200
08/02/13 10:07 AM
08/02/13 10:07 AM
ill
dennismopar73 Offline
ill
I will have tom answer YES ,it is possible,we have a 71 challenger that happens to have an interrior package that was only available ,,they say in 70 so I guess anything could have been ?
Re: 70 dash in 71 Cuda...is it possible from the factory? [Re: dennismopar73] #1478201
08/02/13 10:28 AM
08/02/13 10:28 AM
Milwaukee WI
R_Blaha Offline
R_Blaha  Offline
Milwaukee WI
I had a 71 barracuda with a 318 that was a early build with a 70 dash in it. The car was mostly original when I got it, so the dash was never out.
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: 70 dash in 71 Cuda...is it possible from the factory? [Re: R_Blaha] #1478202
08/02/13 10:29 AM
08/02/13 10:29 AM
italy
italy
Any idea of the vin or the production date?
Re: 70 dash in 71 Cuda...is it possible from the factory? [Re: antonellomopar] #1478203
08/02/13 10:34 AM
08/02/13 10:34 AM
Milwaukee WI
R_Blaha Offline
R_Blaha  Offline
Milwaukee WI
That I don't remember, I cut the car up back in 92, it was a parts car back then, now days that car would of been clean! lol
1989 Mustang GT
1993 mustang lx 5.0
2013 CVO Roadglide
Re: 70 dash in 71 Cuda...is it possible from the factory? [Re: antonellomopar] #1478204
08/02/13 11:21 AM
08/02/13 11:21 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Antonello,
Are you asking about just the instrument cluster or the entire dash pad?
I have seen several early 1971 cars (up to mid September) that have 1970 interior parts. Specifically, Dash pads, center consoles, and Saddle Tan interior parts.
Many have been black dash pads and consoles. But some with colored interior (a blue one and a green one comes to mind).
If it is just the Rallye Instrument cluster, then yes. The factory would just use what ever they had in stock.
Are you wondering because of an assembly date of 1970 on the instrument cluster? or because it has a 8,000 RPM tachometer?
I have seen 1970 deck lids on first day production 1971 cars. Also, late 1971 cars, I have seen 1972 parts.
Ola
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: 70 dash in 71 Cuda...is it possible from the factory? [Re: cudaized] #1478205
08/02/13 11:26 AM
08/02/13 11:26 AM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
My early build 71 challenger has "70 only" center console and front buckets. It also had ember gold interior.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: 70 dash in 71 Cuda...is it possible from the factory? [Re: fireeng] #1478206
08/02/13 01:05 PM
08/02/13 01:05 PM
italy
italy
Hello Ola
car has black dashpad and black console from a 70. Other parts are missing. But if the SPD is early september, it could be correct. Gauges are from a 72 or later, with 7000 tach, but have some other guages from an earlier project. Don't know about trunk lid, car was in a dark garage and could't check out ....Seats are from a 70. Door panels and quarter panels are missing. have a 71 column on hand, not sure id there is a column right now.
