hot wiring a fifth avenue for a derby car
#1477124
07/31/13 04:18 PM
07/31/13 04:18 PM
Posts: 138 Los Angeles, CA
71_dramaqueen
Los Angeles, CA
I have a 86 Fifth ave that came into the impound lot without a key and the column locked. I want to make it into a demolition derby car but i want to find out if it runs first. How is the best way to get her going? (if she'll go) Im happy to take a drill, cut wheel, sawzall, hammer, or whatever to the column. I would rather know what to do than just start hacking and risk messing up the shifter.
thanks
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: hot wiring a fifth avenue for a derby car
[Re: 71_dramaqueen]
#1477126
07/31/13 04:37 PM
07/31/13 04:37 PM
Posts: 721 Seminole County FL to Plymouth...
Barry70GTX
Pull the steering wheel and remove the steering lock parts. When you get to the key lock assembly, knock it out with a punch and hammer. look at how the switch works. Now put the wheel back on and you can start it with your finger.
NMCA NSS 67 Coronet
[Re: 71_dramaqueen]
#1477127
07/31/13 06:29 PM
07/31/13 06:29 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The neighbors have a 86 Fifth ave I dont have a key and the column locked. I want to make it into a demolition derby car but i want to find out if it runs first. How is the best way to get her going? (if she'll go) Im happy to take a drill, cut wheel, sawzall, hammer, or whatever to the column. I would rather know what to do than just start hacking and risk messing up the shifter.
thanks
THIS is the more likely scenario.... ![](/ubbthreads/images/graemlins/boogie.gif)
