part fell off my 67 gtx what is it?? #1476631
07/30/13 09:48 PM
07/30/13 09:48 PM
Ohio
billohio Offline OP
billohio  Offline OP
Ohio
when I took the engine out of the car I found this on the floor near the clutch linkage, steering column and master cylinder area. all of which I messed with. Any ideas on where it goes? I thought it might be something off where the z bar goes into the frame but it doesnt really fit.
Re: part fell off my 67 gtx what is it?? [Re: billohio] #1476632
07/31/13 12:15 AM
07/31/13 12:15 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
91 views an no answers tell me that it probably doesn't belong to your car...
Re: part fell off my 67 gtx what is it?? [Re: billohio] #1476633
07/31/13 12:16 AM
07/31/13 12:16 AM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
Maybe a shim for the starter.Just a guess....
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: part fell off my 67 gtx what is it?? [Re: JOES4FORTY] #1476634
07/31/13 01:37 AM
07/31/13 01:37 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
Looks like something the clutch return spring hooks to .
Re: part fell off my 67 gtx what is it?? [Re: billohio] #1476635
07/31/13 01:40 AM
07/31/13 01:40 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
spacer for between the shifter and aluminum bracket that bolts to the tailshaft
Re: part fell off my 67 gtx what is it?? [Re: mopwrd340] #1476636
07/31/13 01:41 AM
07/31/13 01:41 AM
Ohio
billohio Offline OP
billohio  Offline OP
Ohio
My dad suggested the jack! The guy who restored it didn't know. Then we thought of the items the last owner changed Hurst shifter.... its some kind of spacer. Part number showed up on Jegs website. At least it isn't something like pull the tranny to fix
Re: part fell off my 67 gtx what is it?? [Re: billohio] #1476637
07/31/13 01:43 AM
07/31/13 01:43 AM
Ohio
billohio Offline OP
billohio  Offline OP
Ohio
Thanks guys.
Re: part fell off my 67 gtx what is it?? [Re: billohio] #1476638
07/31/13 01:45 AM
07/31/13 01:45 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
winner!! eBay
Re: part fell off my 67 gtx what is it?? [Re: 6bblgt] #1476639
07/31/13 01:57 AM
07/31/13 01:57 AM
Ohio
billohio Offline OP
billohio  Offline OP
Ohio
Winner gets to help install it! My hands are so cut up from putting the engine back in. I should have a hard time recomending headers. Spent a day trying to get a dipstick installed
Weird thing on the part. I keep seeing Muncie listed with it.
Re: part fell off my 67 gtx what is it?? [Re: billohio] #1476640
07/31/13 04:47 PM
07/31/13 04:47 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That's because it's not a mopar part , if the trans has the right adapter bracket for a mopar shifter there is no part like that needed.
Re: part fell off my 67 gtx what is it?? [Re: JohnRR] #1476641
07/31/13 05:06 PM
07/31/13 05:06 PM
Ohio
billohio Offline OP
billohio  Offline OP
Ohio
I put it on. Has a competition plus shifter and aluminum adapter. At one time it had an inland but it disappeared
Re: part fell off my 67 gtx what is it?? [Re: billohio] #1476642
07/31/13 05:12 PM
07/31/13 05:12 PM
JohnRR Offline
JohnRR  Offline
Yes it will bolt on but if the trans has the correct adapter it is not needed and may actually cause a shifter rod angle misalignment.
Re: part fell off my 67 gtx what is it?? [Re: JohnRR] #1476643
07/31/13 06:48 PM
07/31/13 06:48 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
It is needed if you install a newer hurst shifter and if you want to ever shift into reverse. DAMHIK
Re: part fell off my 67 gtx what is it?? [Re: moparpollack] #1476644
07/31/13 08:04 PM
07/31/13 08:04 PM
Ohio
billohio Offline OP
billohio  Offline OP
Ohio
It seemed to work OK before. I bought the car in January and drove it 300 miles and had it hauled to Ohio. Roads bad so I pulled the engine to fix the rear main seal. Took forever to get back from machine shop. I thought it looked ok with the adaptor out. Rods were straight.
