Re: part fell off my 67 gtx what is it??
[Re: billohio]
#1476637
07/31/13 01:43 AM
07/31/13 01:43 AM
Posts: 344 Ohio
billohio
Ohio
[Re: billohio]
#1476638
07/31/13 01:45 AM
07/31/13 01:45 AM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
spacer for between the shifter and aluminum bracket that bolts to the tailshaft
winner!! eBay
[Re: billohio]
#1476640
07/31/13 04:47 PM
07/31/13 04:47 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I keep seeing Muncie listed with it.
That's because it's not a mopar part , if the trans has the right adapter bracket for a mopar shifter there is no part like that needed.
[Re: billohio]
#1476642
07/31/13 05:12 PM
07/31/13 05:12 PM
JohnRR
I put it on. Has a competition plus shifter and aluminum adapter. At one time it had an inland but it disappeared
Yes it will bolt on but if the trans has the correct adapter it is not needed and may actually cause a shifter rod angle misalignment.
[Re: JohnRR]
#1476643
07/31/13 06:48 PM
07/31/13 06:48 PM
moparpollack
Lil Herman
Lil Herman
85086
It is needed if you install a newer hurst shifter and if you want to ever shift into reverse. DAMHIK ![](/ubbthreads/images/graemlins/wave.gif)
