Challenger rear ride height #1476620
07/30/13 08:44 PM
07/30/13 08:44 PM
central P.A.
HEMIDOG 70 Offline OP
central P.A.
I would like to pick the rear of my Challenger up just a little. I have the Mopar xhd springs on it. I have already removed them once and had them rearched they sagged back down. The question is would add a leafs pick the car up a little without destroying the ride or do I need to get new rear leafs again? The shackles I'm running are the e&b body ones from Mancini. the resto e body one they sell are about 1/4" longer but I don't think that will make much difference. I would only like to lift it about 1" to 1 1/2".
Re: Challenger rear ride height [Re: HEMIDOG 70] #1476621
07/30/13 09:20 PM
07/30/13 09:20 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
I know I caught some slack on this this board but I lifted mine with $60 air shocks. I just run about 20 pounds in them and the car still rides decent.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: Challenger rear ride height [Re: fireeng] #1476622
07/30/13 09:52 PM
07/30/13 09:52 PM
IN
ahy Offline
ahy  Offline
IN
I run XHD's on my Challenger and they had dropped a bit too low. I also wanted a higher spring rate. I had a local spring shop add a full leaf to each for $100. It picked the rear up about an inch and increased spring rate from about 140 to 170. Just what I was after.
Re: Challenger rear ride height [Re: ahy] #1476623
07/31/13 01:14 PM
07/31/13 01:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I went the opposite direction. When I put the caltracs & split mono leafs I went with a -1" in ride height due to the tall 315/60/15 (30x13) tires to keep it low.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Challenger rear ride height [Re: 6PKRTSE] #1476624
07/31/13 10:34 PM
07/31/13 10:34 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Air Shocks. Been on for 8 years. Never have to worry about sagging springs.
Re: Challenger rear ride height [Re: Dads426] #1476625
07/31/13 10:42 PM
07/31/13 10:42 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
you can fix that easy. take the springs back out. put it in a hyd. press and cold bend the main leaf close to the spring eye. lay the spring on its side to measure the true arch and adjust accordingly. this will not sag like a re-arch across the whole spring. it is a change in the fixed mounting point.
Re: Challenger rear ride height [Re: Dads426] #1476626
07/31/13 11:39 PM
07/31/13 11:39 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
....or one side lower than the other.
Painted mine black and got that slight rake that a Challenger looks best at. No one's ever questioned them either.
Mo' Farts
Moderated by "tbagger".
Re: Challenger rear ride height [Re: Grizzly] #1476627
08/01/13 12:01 AM
08/01/13 12:01 AM
IN
ahy Offline
ahy  Offline
IN
Its been posted many times but I'll add. The upper shock mount is made of (heavy gauge) sheet metal. Its not designed to handle spring loads. If the upper shock mount cracks or the holes get ovaled out by airshock loads it is a very invasive repair. Best to keep the spring loads on the springs if you are really driving it.
