Antifreeze in 05 CTD. #1476527
07/30/13 04:35 PM
07/30/13 04:35 PM
Penna
70satelliteguy Offline OP
Penna
My 05 CTD has 70,000 miles on it with the original factory coolant. I want to change it despite the fact that they say it will last 100,000 miles. Do I have to use the Special coolant recommended by Dodge that has HOAT or can I just use regular antifreeze?
Thanks Mike
Re: Antifreeze in 05 CTD. [Re: 70satelliteguy] #1476528
07/30/13 05:44 PM
07/30/13 05:44 PM
ky.
K
kenworth_goose Offline
K
ky.
If it has "Deathcool" get it out! flush with lots of water. Refill with green or extended life antifreeze.
Re: Antifreeze in 05 CTD. [Re: 70satelliteguy] #1476529
07/30/13 06:25 PM
07/30/13 06:25 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
Use the right stuff. You can buy Zerex G-05 at NAPA or CarQuest or buy the factory stuff from the dealer. Ford dealer sells the stuff too. It's all about the same price. $13-$15 per gallon.
Re: Antifreeze in 05 CTD. [Re: kenworth_goose] #1476530
07/30/13 08:47 PM
07/30/13 08:47 PM
Penna
Penna
"If it has "Deathcool" get it out!"
kenworth_goose could you explain what this is?
So from what I am understanding that there is a special kind of antifreeze for CTD trucks? does that mean that good old Prestone will not work properly or will damage my truck?
Thanks MIke
Re: Antifreeze in 05 CTD. [Re: 70satelliteguy] #1476531
07/30/13 09:27 PM
07/30/13 09:27 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Thanks MIke
ok its pretty simple really
his deathcool= Dexcool which is only in GM cars and I wont even get into that debate
Your Cummins came from the factory with HOAT coolant do not mix it with the plain old green stuff of years gone by. You can either spend a lot of time flushing and draining to get it all out then you can run what ever you want.
Or you can get the HOAT coolant from the dealer and drain and fill or there is also a universal coolant from Preston and others that they say you can mix with any coolant.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Antifreeze in 05 CTD. [Re: dusturbd340W5] #1476532
07/30/13 10:17 PM
07/30/13 10:17 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
It's time..... Get three gallons of coolant at the dealer. Put a 5 gallon bucket under the petcock and let her drain. Mix 50/50 with distilled water. Gaskets and seals were designed around using that coolant.
Re: Antifreeze in 05 CTD. [Re: J_BODY] #1476533
07/30/13 11:25 PM
07/30/13 11:25 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Just a suggestion, if you have a big truck shop nearby, see if they can check the acidity levels in the antifreeze after you flush and refill. It just uses test strips.
It will tell you if need to repeat flush and fill soon.
I have seen some nasty things happen with neglected cooling systems on big trucks.
It is routine for us at every periodic maint.
Co I work for runs over 100 trucks. We are the main terminal here, and get the major stuff from all our other yards over NM, TX, OK, and MO.
I agree, use distilled water!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Antifreeze in 05 CTD. [Re: old_goat] #1476534
08/08/13 09:21 PM
08/08/13 09:21 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
X2 on the test strips. Checks the Ph level and a couple of other things like freeze point. If the levels are off it will cause cavitation pits to eat thru the cylinders. Fleetgard sells a DCA (no clue what it stands for but it's critical stuff for a diesel) additive to correct this and the KW or whatever dealer will have it in stock and it's cheap.
If you can add a coolant filter, Fleetgard sells a pre-charged filter that will maintain the DCA and anti corrosion levels. Test with the strips every oil change and change the filter accordingly. Coolant should last almost forever then.
Kevin
