Re: Antifreeze in 05 CTD.
[Re: kenworth_goose]
#1476530
07/30/13 08:47 PM
07/30/13 08:47 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"If it has "Deathcool" get it out!" kenworth_goose could you explain what this is? So from what I am understanding that there is a special kind of antifreeze for CTD trucks? does that mean that good old Prestone will not work properly or will damage my truck? Thanks MIke
[Re: J_BODY]
#1476533
07/30/13 11:25 PM
07/30/13 11:25 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Just a suggestion, if you have a big truck shop nearby, see if they can check the acidity levels in the antifreeze after you flush and refill. It just uses test strips. It will tell you if need to repeat flush and fill soon. I have seen some nasty things happen with neglected cooling systems on big trucks. It is routine for us at every periodic maint. Co I work for runs over 100 trucks. We are the main terminal here, and get the major stuff from all our other yards over NM, TX, OK, and MO. I agree, use distilled water!
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
