Billet 7290 Yoke Help #1475647
07/29/13 12:19 AM
07/29/13 12:19 AM
NY
Beep Beep Offline OP
NY
Can some please tell me what is the proper torque spec on a 5/16 U bolt for a Billet 7290 Yoke.
Re: Billet 7290 Yoke Help [Re: Beep Beep] #1475648
07/29/13 12:43 AM
07/29/13 12:43 AM
Snug it up, no more than 300 inch lbs (25 ft. lbs) the U bolts don't do anything other than limit the forward and rearward movement of the U joint caps, the pinion yoke does all the work under power
Re: Billet 7290 Yoke Help [Re: Cab_Burge] #1475649
07/29/13 07:29 AM
07/29/13 07:29 AM
NY
NY
Thanks Cab Burge
