Green bearing replacement #1475499
07/28/13 10:49 PM
07/28/13 10:49 PM
dark side of the moon
Dougsmopars Offline OP
My car has the green bearings in it and they are junk. I want to go back to the stock style set up. Where can i get a kit with the end play adjuster included? Not used with green bearings and i don't have any spare axles to get it from.
Re: Green bearing replacement [Re: Dougsmopars] #1475500
07/28/13 11:13 PM
07/28/13 11:13 PM
crisfield, maryland 21817
8
82ramIndy493 Offline
Why do you say they are junk? What kind of car are they in and what do you do with the car? Is it Drag, Street or a little of both. I have ran those bearings in a short bed truck for years and run at the track at 10:80's and have never had an issue since 1996. I have heard of axle fitting issues that can tear bearings up. I would talk to Dr Diff about it. He could help you with the problem and probably set you up with any parts you need.
Re: Green bearing replacement [Re: 82ramIndy493] #1475501
07/28/13 11:52 PM
07/28/13 11:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
You cant get the adjusters any more.. Unless you can find good used 1s you are stuck with the greens.. Dr diff has the better style of greens..
I am truckless..
Re: Green bearing replacement [Re: 340SHORTY] #1475502
07/28/13 11:57 PM
07/28/13 11:57 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I have several 8 3/4 rears. I am sire I have what you need. Contact me with a p.m. if interested.
I have mechanical Aptitude.
I can screw up anything.
Re: Green bearing replacement [Re: 340SHORTY] #1475503
07/29/13 05:58 PM
07/29/13 05:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Dr Diff also has billet adjusters for use with the original tapered bearings.
Re: Green bearing replacement [Re: John_Kunkel] #1475504
07/29/13 09:20 PM
07/29/13 09:20 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
