Fender mounted turn signal wiring #1475113
07/27/13 10:32 PM
07/27/13 10:32 PM
Maine
shipfitter_sjd Offline OP
Maine
71 Plymouth B Body: Just trying to figure out how to properly route the wiring from the fender mounted turn signals as they come down into the wheel well. Seems like the connector mates to the wiring from the from the front parking lights and that is via an opening in the front of the wheel well.
Is that right? What keep the wiring from being eaten up by the wheel? Anyone have pics or an explanation?
Thanks,
Steve
Re: Fender mounted turn signal wiring [Re: shipfitter_sjd] #1475114
07/28/13 12:27 AM
07/28/13 12:27 AM
Ohio
dobie Offline
dobie  Offline
Ohio
Not sure about your '71, but on my '68 there is an inner fender piece that needs to be removed to install the lights. After hooking the lights up, re-install this small piece and the wheels will never get close to contact. On mine, if you look up into and to the front of the wheel well, you can see the covering that Im talking about.
1968 Plymouth Road Runner 383 4 speed
Re: Fender mounted turn signal wiring [Re: shipfitter_sjd] #1475115
07/28/13 12:53 AM
07/28/13 12:53 AM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
